Old 06-04-2001, 11:06 AM
edjog edjog is offline
Default PTF audio & Cubase MIDI?
Got no joy posting this in SadRobot's thread, so starting a new 1!
I have tried using IAC Bus with PTF and Cubase.
1st problem: PTF failed to open with a 227 error. Solution, close Cubase, open PTF, then open Cubase.
Next thing is wierd: I disabled the audio engine in Cubase because I only wanted it for MIDI and set it to recieve MTC from IAC Bus. Set PTF to generate MTC to IAC Bus, sorted I thought, synched playback!
Except that I could only get audio from channels 1&2 in PTF. Even quitting Cubase and then quitting everything and restarting the iMac did not help. I returned every thing back to normal in that session and still: only 2 channels of playback. Any ideas how I can get 8 channels of audio in PTF and full use of MIDI in Cubase, at the same time?
Computer= iMac G3 500MHz, 512 MB RAM
HTML code is On
Cubase SX3 abd Cubase 4 LE STILL no MIDI! Shiver1 MIDI 2 12-02-2008 10:30 AM
Midi in Cubase-Audio in ProTools stretto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-19-2002 12:52 AM
Cubase as midi editor and PT LE as audio CFS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-01-2001 12:33 AM
Cubase 4.1. Getting Midi and Audio to work? lifeline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-22-2000 08:45 AM
Using Cubase 4.1 with Digi 001 midi&audio? lifeline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-21-2000 08:53 AM
