Old 04-14-2002, 02:19 PM
John H John H is offline
Default difference between PT24, PT24 Mix and Mix+ ?
I've found someone selling a PT24 system with dual SCSI drives, a 9500, 16bit I/O and PT 4 for £1,600.
I'm sick because I can't buy it right now but I was wondering if a PT24 system would run the latest PT 5 version and whether it's faster than host based LE ?
Old 04-15-2002, 08:28 AM
DigiTechSupt's Avatar
Default Re: difference between PT24, PT24 Mix and Mix+ ?
Originally posted by John H:
...I was wondering if a PT24 system would run the latest PT 5 version
<font size="2" face="Verdana, Arial">Yes.
...and whether it's faster than host based LE ?
<font size="2" face="Verdana, Arial">Since the mixing/DSP processing is performed on the cards, then it frees up CPU resources to do other things (screen redraws, soft synths, QuickTime, etc).
Brent
Avid Audio Tech Support
Support FAQ
Old 04-15-2002, 08:51 AM
Thanks!
I'm thinking that a used PT|24 system would be better upgrade for me later in the year than a new G4 because I'd get guaranteed performance out of the DSPs, plus I could still use as much host based power as my G3 gives me now ontop of whatever PT|24 does on it's own.
looking in the digirack pdf file it seems that a Mix system can run 168 4-band EQs, compared with the 26 my Beige G3 can do now that's very impressive and as far as I know the PT|24 system is half the speed of a Mix system so should I be looking at about 80 plug-ins from one of those without an additional DSP farm ?
I put up a little benchmark session a while ago and seeing as a dual Ghz G4 is barely more than 3 times the speed of my beige G3.
The new HD system can run over 250 4-band EQs without even reaching it's maximum so I'd assume a used PT|24 system is the way to go seeing as I'm always on a really tight budget with it just being a hobby.
Old 04-16-2002, 07:20 AM
...and as far as I know the PT|24 system is half the speed of a Mix system so should I be looking at about 80 plug-ins from one of those without an additional DSP farm ?
<font size="2" face="Verdana, Arial">-No, this is not true. Mix cards are significantly more powerful than the original DSP Farms.
For example:
Number of instantiations for DigiRack EQII 4-band (Mono):
Mix Farm: 24 (per chip)
DSP Farm: 5 (per chip)
Brent
Support FAQ
Old 04-16-2002, 08:11 AM
Robert U Robert U is offline
I have a MIX Cube system with 2 additional DSP cards that were used in my old d24 system. These two extra cards helps me a lot. Plug ins like Autotune, LexiVerb etc takes the same amount as my MIX cards. Besides, the MIX system has 3 different kinds of chips while the d24 have the same type.
My experiences are that you will get more power than you think on the old d24 cards than theory says.
-Robert
www.extensivemusic.com
What difference between PT24 and PT24mix? diegogat General Discussion 2 11-04-2002 08:47 AM
pt24 into mix fxbuilder Pro Tools TDM Systems (Mac) 0 02-16-2001 02:00 PM
001 Mac vs. PT24 NT Tinnitus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-10-1999 10:36 AM
How many 888/24 on PT24 ? Uma Pro Tools TDM Systems (Mac) 2 12-05-1999 04:03 AM
AV and PT24 New Dimension Studios Post - Surround - Video 1 08-10-1999 09:30 PM
