Old 05-10-2019, 03:05 AM
Led Led is offline
Default D-Command quick assign default eq/dynamics
Hi, I just switched to a D-Command ES from the artist controllers and am loving it. Forgive me if this is somewhere in a thread but I can't find it. The user manual mentions default eq and dyn can be 'quick assigned' but it doesn't say how. On the artist you just hit the eq button and it asks 'add eq?' and you push the rotary below it and it is added. Is there something similar on the D-Command?
Thanks
Old 05-10-2019, 11:32 PM
Led Led is offline
Default Re: D-Command quick assign default eq/dynamics
So I think I worked it out, the default eq and dyn appear in the plugin page but at the top level so you don't have to page through all eq/dyn to find them. Iy is one more button press than with Eucon, I hope my finger can take it.
Old 05-12-2019, 02:30 PM
rmccam rmccam is offline
Hey Led,
This sort of touches on one of my questions (I'm about to buy a D-Command myself): I know that you can custom map plugins across the channel strips but I'm assuming the actual dynamics and EQ sections in the "master" section of the console can be used to map non-Avid plugins, right?
I primarily use McDSP Channel G and would love for it to map there as opposed to across the channel strips.
Thanks!
Ryan McCambridge
Producer • Sound Designer • Mixer
Old 05-12-2019, 02:34 PM
Originally Posted by rmccam View Post
Hey Led,
Thanks!
That post lead me to other suggested posts which seem to infer that it can but that the mapping might be a bit weird.
Ryan McCambridge
Old 05-12-2019, 07:17 PM
Will Russell's Avatar
Will Russell Will Russell is offline
Hey Led,
Thanks!
Longtime D-Command user here. Most eq and dynamics, map really well to the dedicated eq and dynamics section of the D-Command. Any track that is focused will present whatever eq/dyn you have on that track to the dedicated EQ/dyn controls. If you have more than 1 eq or comp you can toggle through them. Its so great and so easy!
The McDSP Channel G was specifically designed to integrate easily with the Icon controllers and it works like a charm! I've done plenty of mixes with all tracks populated with Channel G and then you just mix like a console! With Channel G Compact not only do the parameters map perfectly but the knobs on the plugin UI are located in the same physical location as the D-Command.
Most other channel strips map predictably and well, as do most eqs and comps. I use all three BX-Consoles the same way as Channel G, and you don't have to think about which tool to choose, you just mix.
In addition you can display eq/dyn parameters on the rotary encoders in each channel strip and page through parameters 2 rows at a time, and you can also set the D-Command to show GR meters on the channel when you have comp parameters on the rotary encoders. So you could set up the console to have rotary encoders on multiple track all controlling the threshold and have GR meters displayed. Because any parameter assigned to the rotary encoders can be flipped to faders, you can adjust multiple channel comp thresholds super fast using faders.
You get the picture. The D-Command is a sweet console and the prices are dropping fast.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 05-12-2019, 07:33 PM
ProtoolsLover ProtoolsLover is offline
This video should help you get going!
https://drive.google.com/drive/folde...XB1SHM3X29MTHc
Old 05-12-2019, 07:44 PM
Thanks a million! This is great. I’ve used a d-command before but not enough to know its nuances.
Thanks again.
Ryan McCambridge
Old 05-12-2019, 08:31 PM
Led Led is offline
Hey Led,
Thanks!
Hi Ryan, I've only had it a few days, so I could be wrong, but yes they will as long as they are eq or dynamics plugins. You can use the cycle button in the master section to change through them all. I don't know the Channel G, but my SSL plugins, if I use a channel, the dynamics and eq for that channel both come up in the centre section. AS far as actual mapping I believe that is determined by the plug manufacturer, and if you want a custom setup of controls you map them to the faders. Maybe someone more experienced can elaborate. As I say I've only had it a few days, but already it is wayyy better than the artist series I was previously using and it's nice to use my ears again instead how an eq looks.
Old 05-12-2019, 08:32 PM
Led Led is offline
Protoolslover, I can't access that video, it says I need to request permission which I did, so if you get a notice it's just me, not some Nigerian Prince asking. Thanks
Old 05-12-2019, 09:51 PM
You should be able to, PM me with your email and I’ll try it that way.
Assign Pause & key command to soft keys? mikekiraly1 Artist Series 2 02-03-2012 10:29 AM
Default Eq and Dynamics zeeman Pro Tools TDM Systems (Mac) 5 07-15-2010 04:59 PM
D-Command assign multiple outs? macaholic ICON & C|24 2 03-17-2009 06:55 AM
7.2-User-definable default EQ & Dynamics question PMoshay Pro Tools TDM Systems (Mac) 4 08-03-2006 11:50 AM
EQ and dynamics panels on D-command MikeJaxx ICON & C|24 6 08-22-2005 07:35 AM
