Old 07-23-2011, 12:20 PM
smc917 smc917 is offline
Default AVID MADI - connect 2 MADI units?
I need 96 IO from my PT9HD system.
Can I connect two Avid MADI units to my system?
I believe my max. IO will still be 96.
But can I use two MADI units and connect the second unit with just one Digi cable thus getting just the 32 IO only from the second unit?
If I cannot use two MADI units can I use one MADI unit and 2 x 192s?
Thanks.
Old 07-23-2011, 01:59 PM
kcfroines kcfroines is offline
Default Re: AVID MADI - connect 2 MADI units?
You could connect 2 HD Madi units to your system, as long as you have an HD4 system....
I'm not sure about the 1 1/2 madi unit situation, but I don't think that would work.
You could use 1 madi and 2 192's, but again you'd need an HD4 system.
I'm assuming you're running all channels to a digital console, right?
Old 07-23-2011, 06:12 PM
Yes all channels digital to a digital console.
Old 07-25-2011, 11:14 AM
gsilbers gsilbers is offline
have u seen the SSL madi interfaces?
the new one has a LOT of channels.
maybe too much :)
Old 07-25-2011, 02:38 PM
1m1 1m1 is offline
Yes, you can do 96 I/O with two MADI units if you have an HD3. That's what I do. Each MADI can take two Digilink connectors, so on of the units has two cables plugged in, the other has only one.
OMNI with the MADI IF? Mitch Griffin Pro Tools HDX & HD Native Systems (Mac) 8 03-21-2017 02:08 PM
HD MADI Supports Frame Pattern MADI ??? misterGOLD Pro Tools HDX & HD Native Systems (Mac) 2 02-10-2014 11:43 PM
S3L and madi klaukholm VENUE Live Sound Systems 1 10-08-2013 12:50 PM
Avid buys Euphonix....NAtive MADI? gsilbers Pro Tools TDM Systems (Mac) 3 04-13-2010 12:28 PM
HD PCIe with SSL Delta link MADI HD Alpha link MADI AX Juraj Bernáth Pro Tools TDM Systems (Mac) 3 09-10-2009 07:13 AM
