Old 06-07-2011, 07:53 PM
PeterScherr PeterScherr is offline
Talking Feature request: Pre Fader Sends follow Main Faders
Here's one for you:
Pre Fader sends follow main channel faders...
When I do live sessions, I always derive a reference mix for musicians to pick up at the end of the session by running sends from each track to a stereo track. (via a stereo aux with a bit of gentle limit/boost) These are always post fader and FMP, so that I can mix on the fly to the reference track.
But when I need to solo a track for technical reasons, the signal to the stereo ref is interrupted. If there was a way to have the signal path of sends be pre fader, but have a Follow Main Fader function, this would solve the problem.
Perhaps another way would be to be able to independently solo safe sends and main faders... So that if you solo safe a send, the main fader solo behavior would not be affected.
NB, of course, you can't listen to this ref while recording because it is slightly delayed. I always mute it while tracking.
Any ideas on this would be welcome...
www.peterscherr.com
Old 06-09-2011, 10:45 AM
daeron80 daeron80 is offline
Default Re: Feature request: Pre Fader Sends follow Main Faders
Interesting idea. You should put that on Ideascale as a Feature request with a heading something like "Add Solo-safe ability to Sends."
David J. Finnamore
Nyquist was right.
PT 2019.6 Ultimate | Omni | macOS Sierra
PT 2019.6 | Saffire Pro 40 | Win10
Old 06-10-2011, 07:34 AM
Originally Posted by PeterScherr View Post
Here's one for you:
www.peterscherr.com
Sorry if I'm misunderstanding, but aren't you just asking for a standard AFL/PFL solo mode which ProTools already has?
best,
rich
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 06-10-2011, 08:06 AM
He wants solo-safe, post-fader sends so he solo tracks while printing a Send-fed mix that has levels controlled by channel faders.
David J. Finnamore
Nyquist was right.
Old 06-10-2011, 08:11 AM
A standard AFL/PFL mode takes care of this - solos are routed to your designated AFL/PFL path and are not destructive. PT supports this.
best,
rich
Old 06-10-2011, 11:08 AM
Only in HD/CPTK, I believe.
David J. Finnamore
Nyquist was right.
Old 06-10-2011, 11:22 AM
Yes, correct.
Old 06-10-2011, 01:19 PM
Thanks for the reminder. I'd forgotten what AFL/PFL was for. Last time I used it was on a Trident B console in like 1995.
David J. Finnamore
Nyquist was right.
Old 06-11-2011, 07:37 AM
HI Rich,
Thanks for your reply. Running HD. Can you please clue me in on this AFL PFL thing?
Thanks much!
Pete
Old 06-11-2011, 08:39 AM
HI Rich,
Thanks much!
Pete
Hi Pete - just read the ref manual - there's a whole section on AFL/PFL modes -it explains it better than I could.
best,
rich
[IMG] code is Off
'Follow Main Pan' on effect sends? jasonlane Tips & Tricks 3 02-19-2014 11:09 AM
Feature request or bug fix? Sends view... Ryan Hafer Artist Series 0 05-22-2012 11:29 PM
Sends default to follow main pan pref Not on stereo tracks? crizdee Pro Tools TDM Systems (Mac) 2 12-15-2010 08:18 PM
Foldback sends mirror Mix window main faders? turnyouritch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-03-2010 11:13 AM
fader flip between main faders and aux sends Sdesign Pro Tools TDM Systems (Mac) 7 08-23-2007 12:40 PM
