Old 07-21-2002, 11:03 AM
DENNIS MK DENNIS MK is offline
Default Lock up with USD
Hi
I'm using a betacam locking up with the protools, it spend about 15 sec to lock up, the USD can display the time code at once, did any one can give me some suggestion? IS the problem from the USD or from the Protools 5.1.1?
Thanks
Dennis
Old 07-21-2002, 06:24 PM
Danny Caccavo Danny Caccavo is offline
Default Re: Lock up with USD
Firstly, I assume you are all locked to "house sync" - in which case, you should have the USD settings to "video ref" and "LTC" - make sure you don't have the clock window set to "LTC", because if you do, PT will derive clock from the speed of the LTC.
Also, for good measure, go to "peripherals", and change the value of "min sync time" under "synchronization" - just bump it one frame or another. I find that 25 frames works pretty well.
dc
Old 07-22-2002, 07:51 AM
Dear Danny
I have try it, but still can't lock up , it still take about 15 sec to lock up, I have give the video ref to it. Is it somethings I miss?
Dennis
Num Lock? WorkingEngineer ProControl, Control|24, Command|8 8 07-05-2004 07:55 AM
LOCK UP!!!!!!!! dwdrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-26-2002 11:56 AM
To Lock or Not....NOT stunningfuture 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-03-2001 12:54 AM
can i lock pt le to mtc? audioworks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-17-2000 09:28 PM
HELP...PT won't lock to LTC skidd Pro Tools TDM Systems (Mac) 9 02-13-2000 11:58 PM
