Old 03-26-2009, 01:33 AM
SoundReplay SoundReplay is offline
Question ReelTape vs. McDSP AC vs. DUY Valve/Tape
I want to buy some "analogue emulation" plugins, especially for the master bus.
Do you have some experience with
Digidesign Reeltape suite or McDSP AC2 or DUY Valve/Tape? I want to buy the TDM versions.
So I want to know which one of the three is the most versatile to use and would yield the best result.
I saw a video lately from MILAR (Charles Dye) using both McDSP AC and DUY on the same session.
I could do a demo download of course, but I just want to know what your preference is.
Many thanks!
www.soundreplay.com
Old 03-26-2009, 02:22 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: ReelTape vs. McDSP AC vs. DUY Valve/Tape
Many thanks!
they are both good and both get equal use with me! AC is more economical with chip usage i find generally DUY gets more use on tracks and AC gets more use on busses and mix bus.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 03-26-2009, 05:39 AM
Fidelis Fidelis is offline
Don't forget to demo cranesong Phoenix. The best TDM plugin I have!
http://www.ricardomosca.com
Intel Mac Pro 12 core 3.33 GHz, 20GB RAM, OSX 10.10.5, PT HDX, PT 12.8, SSL 4040G+, tons of outboard
Mac Book Pro 2.4Ghz Duo, 4GB RAM, OSX 10.10.5, PT Vanilla 12.8
Old 03-26-2009, 08:43 AM
lifer lifer is offline
Ditto!
I use these more than AC1 & 2 etc..couldn't live without them.
Win 7 Pro 64
PT 10 HD, HD4 Accel
Jetway JNAF92-Q67
Intel 2700k 3.8ghz
16GB Crucial Ram
Old 03-26-2009, 09:13 AM
holden holden is offline
For tape emulation I have AC2, DAD Tape, and TapeHead. I use them all.
AC2
PROS: Many tweakable parameters — Just the sort of product you'd expect from a nerd like Colin. If you are into emulation, this can get you close to many tape sounds you may wish to emulate (except the sound of crumpled tape — looking for that in future updates). Has button to automatically normalize gain. Side benefit: Good educational tool for learning about tapes and tape machines.
CONS: Many tweakable parameters.
DAD Tape
PROS: Fast and easy to use with almost no tweakability. Good for imparting a more subtle and vague tapeyness. Broadly useful due to its subtlety. Selectable for choice of vintage machine, tape speed, and noise reduction curves.
CONS: Not much tweakability. Always makes signal a little louder when inserted (marketing gimmick?) requiring trim adjustment.
TapeHead
PROS: Pretty fast and easy to use with few controls. The controls (drive dial, trim dial, normal-bright switch) are very effective and are capable of radically manipulating sound. Very nice as a distortion plug and for bolder levels of tapeyness. Can be used for subtle effects.
CONS: Drive adjustments always require almost equal turns of the trim dial to maintain loudness — This is a PITA. It would be better if the gain remained constant (e.g. calibrated to pink noise) with drive adjustments. Because the drive dial is scaled for the capability of radical effects, it is touchy for subtle effects.
I also have AC1 and DAD Valve. Similar comments apply in correspondence to AC2 and DAD Tape above.
PT9.0.0, 3.0GHz Mac Pro, OS 10.6.3, 13GB RAM, HD6/Accel, Magma PE6R4, PRE
Old 03-26-2009, 09:21 AM
docric docric is offline
Same here...
DUY gets the most use by far... I tend to need tape emu to be
subtle, which DUY is. When I need the "sledgehammer", I go for
Tapehead.
I also use a Cranesong Hedd's tape emu on the 2 buss,
(The CS Phoenix is modelled after this...) which also sounds great.
Never used ReelTape, sorry...
IHTH...
-C' ya'
Rick
MacPro 6,1; 12 core; 64 Gb RAM; 1 TB Samsung 970 Pro w/ adapter & heatsink; OSX 10.14.5
PT 2019.6.0 Ult.
Burl MS / PT Dock/ Eucon 19.7.0/iPad Air2/ iOS 12.3.1/ProTools|Control
Old 03-26-2009, 09:36 AM
Rubicon's Avatar
Rubicon Rubicon is offline
Hi!
I used AC for a long time, then I just got tired of the sound. It is very glue-like and cool. The problem I have with all these tape emulators is they color a sound in such a way that if you use too many of them, they add up to a frequency bump in an inappropriate place.
Same with the harmonic distortion they introduce. Four of them in a mix can make the effect build up in a bad way. I hope I'm making sense.
These days I tend to get this type of analog effect from the SSL plugs. Same type of saturation and compression, but more subtle.
Rubicon
Wikipedia
IMDB
ITunes
ML 10.8.2, PT 10.3.1 HD Accel 3, Mac Harpertown 32gb Apple RAM, 4 1T Apple Drives, Waves Mercury. Lots of unstable VI's.
Old 03-26-2009, 09:50 AM
JSR JSR is offline
...i recently became addicted to URS Saturation; it's only RTAS for the moment, but they're doing a TDM version.
...a tie for second with me is SPL Twin Tube; that's both TDM and RTAS.
the URS did modeling (various tape heads and mic pre's) where the SPL is it's own beast.
Old 03-26-2009, 10:36 AM
Drew Mazurek's Avatar
Originally Posted by Rubicon View Post
Hi!
Rubicon
I agree.
That's why I make sure I mix it up!! Phoenix, Tapehead, Twin Tube is great, sometimes AC.
www.drewmazurek.com
Old 03-26-2009, 11:31 AM
Thank you all for the constructive feedback!
In the meantime, I did some further research and came across this EQMAG review of several tape emulation plugins.
Some of the comments are subjective to the author, but if I read between the lines...the McDSP AC seems to be the best buy.
http://www.eqmag.com/article/tape-si...e/jul-08/85725
www.soundreplay.com
Distorted / Tape / Valve Amp Vocals Matt Darcy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-21-2008 07:59 AM
PC equivalents for DUY Tape, Valve & McDSP AC2 rlcowa@work2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-08-2005 11:40 AM
DUY Valve or McDsp Analog Channel Last Legend Pro Tools TDM Systems (Mac) 1 12-22-2002 03:30 AM
DuY Tape / Valve experiences? Felix Tips & Tricks 2 02-14-2001 12:52 AM
duy valve/tape fidelman Pro Tools TDM Systems (Mac) 4 01-24-2000 04:37 PM
