Old 04-29-2001, 08:52 AM
zeeman zeeman is offline
Default pt won\'t let me lock after 23:22:00
hey guys,
i'm dumping a film project that was done on da-88's
the remote truck was locked to house sync. when i try to record the last tune which is around 23:32:00 pt won't lock. timecode gets to the mtp/av fine, i see it in the session setup window in pt, but pt won't lock. i can manually record at that point but pt won't lock after around 22hrs.
any help would be most appreciated.
g4/466 640ram/os9.1 pt 5.1
cmz
[This message has been edited by zeeman (edited April 29, 2001).]
MAC OS 10.11.6
2 x 2.26 GHz Quad-Core Intel Xeon 48gig ram
PT 2018.1
Lynx Aurora 16/AES16
Old 04-30-2001, 11:33 AM
SFXPost SFXPost is offline
Default Re: pt won\'t let me lock after 23:22:00
We've had the same experience.......what's up Digi? Anyone find a workaround?
www.creativesoundstudios.com
Old 04-30-2001, 03:00 PM
MarkP MarkP is offline
I've had this problem while loading from location DATs. The work around I found was changing the Session start time in the Session setup window. Maintain Relative positions. Load the clip in and then switching the Session Start back to where it was. Then Pull out the new file showing TC Time Stamp.
Sucks but it works!
Old 04-30-2001, 06:50 PM
hey markp,
thanks for the help.
i'm not sure i get your last statement:
"Then Pull out the new file showing TC Time Stamp".....
plus i can't get lock unless my session start time is 12:00:00:00 pt won't lock any other way....
thanks again
cmz
MAC OS 10.11.6
PT 2018.1
Old 05-01-2001, 05:52 AM
DigiTechSupt's Avatar
-This behavior was recently discovered and logged as a bug.
-Because of its late entry, I am not sure whether it will be fixed in the next release.
Brent
Avid Audio Tech Support
Support FAQ
Old 05-01-2001, 04:36 PM
Glad I could help...I meant delete the file from the edit window, adjust the TC start and then drag it from the region list, that's all but hopefully you figured it out.
Old 05-02-2001, 06:38 AM
thanks again markp,
i will try it tonight.
and thanks digi for responding, at least i now know it's not the dreaded operator error.....
cmz
MAC OS 10.11.6
PT 2018.1
Num Lock? WorkingEngineer ProControl, Control|24, Command|8 8 07-05-2004 07:55 AM
LOCK UP!!!!!!!! dwdrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-26-2002 11:56 AM
To Lock or Not....NOT stunningfuture 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-03-2001 12:54 AM
can i lock pt le to mtc? audioworks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 11-17-2000 09:28 PM
HELP...PT won't lock to LTC skidd Pro Tools TDM Systems (Mac) 9 02-13-2000 11:58 PM
