Old 08-03-2006, 09:05 AM
PMoshay PMoshay is offline
Default 7.2-User-definable default EQ & Dynamics question
in 7.2 the User-definable default EQ & Dynamics says that it is a Icon feature.
Will this work only if you have a icon console?
or will it work on any 7.2 session?
Thanks in advance
P.S. - anyone who is using 7.2 out there, how's the stability so far? any comments would be helpful.
www.PeterMoshay.com
www.LiveFromDarylsHouse.com
Check out new shows on the web each month on the 15th.
Always commercial free, watch on Mac/PC, mobile & tablets.
Old 08-03-2006, 10:08 AM
Jonathan Wales Jonathan Wales is offline
Default Re: 7.2-User-definable default EQ & Dynamics question
No,
the defaults will also be available in the pull-down menu in any setup.
Jonathan Wales
Sonic Magic Studios
Culver City CA
Old 08-03-2006, 10:44 AM
crizdee's Avatar
crizdee crizdee is offline
Thanks in advance
No they don't work on any system, only icon i think!
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 08-03-2006, 10:59 AM
Produce_Dept Produce_Dept is offline
They work on any system - what happens is when you go to select a plugin on an insert - and the plugin menu comes up - on the very top will be both your EQ and Dynamics selection. So its easy to select - as it comes up first on the list of plugins. Very handy!
Kurt Bullock
PT 7.4 HD2Accel Digi ProControl
G5 Dual 2.7 3.5gig RAM OS10.4.8
www.zeropointrecording.com
Old 08-03-2006, 11:50 AM
crizdee's Avatar
Like what favourites used to be or still is!! command + shift then select a plugin and it becomes a favourite at the top of the list.
Chris
Producer, Engineer,
www.ukmastering.com
Default Eq and Dynamics zeeman Pro Tools TDM Systems (Mac) 5 07-15-2010 04:59 PM
User definable documentation in the Help Menu sunburst79 General Discussion 5 03-21-2009 10:09 AM
Tab to Transient--user-Definable Threshold teacherman Pro Tools TDM Systems (Mac) 2 11-12-2007 04:42 PM
Are the Soft Keys on the D-Command user-definable?? teacherman ICON & C|24 1 10-18-2007 10:37 AM
User-Definable TAB-THRESHOLD setting teacherman Pro Tools TDM Systems (Mac) 0 08-13-2007 07:24 AM
