Old 02-11-2006, 11:12 PM
John fatman John fatman is offline
Default converting files from 7 to 5.1
is anyone having troubles converting protools 7 files to 5.1 files with out the computer crashing
Old 02-12-2006, 03:31 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: converting files from 7 to 5.1
What is happening exactly?
Have you tried trashing the Digi preferences from user/library/prefs and Database files from all your hard drive partitions.
Also try all the recommendations from the trouble shooting thread at the top of this forum.
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 02-12-2006, 03:58 PM
Audio Card: HD3
Audio Interface: 192 I/O Audio Interface
Miscellaneous: 192 I/O A/D Expansion Card
Digidesign Software: Pro Tools TDM
Version: 7.1.4
Computer Model and Speed: g5 dual 2
RAM: 4gig
Operating System: osx tiger
DAE version:
DigiSystemINIT version:
Other Digidesign and third party products used in the system:
control 24
big ben clock
2 x HD 192 interfaces both with expansion cards
Please give a concise description of the problem:
try to convert from protools 7 to protools 5.1 at save copy to. starts to convert then black screen appears which tells you in about 5 languges to restart computer
Want to convert files as to use on a os9 version 5.1.3 protools setup in foreign studio
when this happened the first time i could not restart the mac had to do a full reinstall now when i atempt this procudure it gets the black screen but will start again
Actions required to reproduce the problem:
just have to try conversion and will do problem again
Troubleshooting already attempted:
have reloaded osx and protools checked disk permissions updated to latest pro tools 7.1.4
this also happens when i tried to consolidate the files as another way of exporting the files to another system
hAVE CLEANED DATE BASE LIBRAY PERMISIONS ETC TO NO AVAIL
Old 02-13-2006, 04:39 AM
crizdee's Avatar
Can you do any other type of "save copy in"ok?
Is it just the one session the crashes? or any session?
As you have done a fresh system and PT install! this is pointing towards the session itself being corrupted? if it is just this session!! or if this is happening in general on all sessions?? then it could be a mac or memory problem etc.
I don't know how many people have tried to convert back to a 5.1 session!
This is something for Digi support to try and confirm.
Chris
Producer, Engineer,
www.ukmastering.com
Old 02-13-2006, 05:51 PM
When i convert session only to 5.1 i have no problems when i try to convert seesion with copy audio files this is when the computer revs high and then crashes
Old 02-13-2006, 05:53 PM
this happens in all sessions but as i say only when i tick to copy audio files
if you have any ideas please reply and could it be a hard drive problem memory should not ba an issue it has 4 gig ram thankyou for your reply
SD2 files not converting to BWF romemtech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 12-20-2009 12:47 PM
Converting Vision files to ProTools or general midi files!!! Paata 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-17-2008 01:11 PM
Converting Cubase files to Pro Tools files... salty_dawg3 Pro Tools M-Powered (Win) 4 12-07-2006 01:58 PM
Converting midi files to audio files Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-19-2003 03:23 PM
converting .mpg to .wav files cmink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-28-2001 10:16 PM
