Old 10-15-2018, 08:31 PM
field3d field3d is offline
Default Protools 2018 and Surface Book 2 Audio Problem
I have almost 2 weeks daily trying to make sound the speakers of a
surface book 2 with pro tools 2018 and nothing. Someone tested in a surface book 2? If yes what was used to make work? I have a focusrite and works fine but when I travel I don’t carry the focus rite and sometimes to use for previews and fast things the speakers are fine. Before install the asio4all driver in playback configuration inside protools I saw only the low latency generic driver (when I’m not connected in the focusrite, of course). And after install the asio4all, I saw the asio4all playback device in protools, but
no matter what output I select there (in asio4all), there is no sound. The
default speakers of the surface book 2 are realtek, but no sound if selected
in asio4all. I see the audio levels monitors move but zero audio. What could be the problem?
Old 10-16-2018, 08:56 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Protools 2018 and Surface Book 2 Audio Problem
What operating system? W10?
Help Us Help You
Chris
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Pro Tools HD 2019.6
Old 10-17-2018, 06:22 AM
Yes exactly. Windows 10 installed.
Old 10-18-2018, 12:41 PM
21 Junipers 21 Junipers is offline
Please open the asio4all and verify your version and configuration. My asio4all (1.0.0.1 x64) has:
1. "All host application to take exclusive control......"(checked)
2. Under Device Name, "Realtek (High definition adio...." (checked) 2 channel 16 bit.
Nothing else is checked and this works on my Surface Pro 5.
Old 10-23-2018, 09:06 PM
Hello I tried to install and reinstall asio4all but I don’t see the options you say, where are located? Look I have the latest version of asio4all:
http://tinypic.com/r/29qe33p/9
There are the advanced options but I don’t see the options you mention. Any idea?
Thank you
How would I connect the Roland TR-8S to 003 Work Surface (PT 2018.4.0), through USB2? jamesleonard General Discussion 6 07-28-2018 10:23 PM
Sierra and ProTools 2018.3, big clicks + audio loss o-matic Pro Tools 2018 12 06-07-2018 01:04 AM
Pro Tools not starting on Surface Book larszi Getting Started 3 04-08-2018 03:10 PM
Does protools run on all Mac Book Pro? kindred 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 10-28-2010 08:56 AM
Red Book audio problem dmaxj General Discussion 3 05-21-2003 08:56 PM
