Old 01-23-2018, 12:40 PM
mrass mrass is offline
Default Digi 001 hardware specs? service manual?
Hello I'm sorry if I missed it but I can't seem to find any info on the digi 001 hardware.
Not even basic information like size and weight and or input/output impedance and so on.
Reason why I'm asking that for a little diy project I'm planning to do I need a pair of microphone pre-amps with phantom power in a nice box, looks like with
a digi 001 I'm 90% done.
Apart from a psu and some other loose ends of course.
Before I buy one (really cheap) I'd like some more info such as mentioned above and absolute best would be a service manual/schematic diagram.
Thanks in advance.
Old 01-23-2018, 12:43 PM
Default Re: Digi 001 hardware specs? service manual?
Also some pics from the inside would already help. Thanks
Old 01-23-2018, 01:00 PM
Ben Jenssen's Avatar
My first PT interface was a Digi 001, and I'm shure I could dig up some info for you. But, I'm also shure that you'll quickly run into some problems. Like, do you have a old computer that will run a old OS that's compatible with the driver, and have PCI slots (not PCIe)? How much have you researched this interface?
Old 01-23-2018, 01:34 PM
Thanks Ben, I will not be using the digi001 in its original way, only the physical box
and some of it's analog circuitry, so without computer interface etc.
Will appreciate anything you can find.
Old 01-23-2018, 02:05 PM
The 001 will not work standalone. You need a PCI computer just to power it, IIRC.
Old 01-23-2018, 02:16 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
There are several microphone preamp with phantom power kits available online as you may have already found. I have a working 001 with a G4 still in use and as ben says it is powered by the pci card with a bespoke cable to the interface so though you could probably rig up some way to make it work I think you would find it cheaper and easier to build/buy something less design intensive
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 01-23-2018, 04:07 PM
Correct.
Old 01-23-2018, 04:15 PM
Only some half decent pots and connectors alone cost more than a 001 over here (below 20 euro).
Let alone the housing and the kit it self and the time to make it look half decent.
I find myself more than capable to modify a 001 into something I need.
The original question remains, any technical specifications, pics?
Old 01-23-2018, 04:20 PM
64GTOBOY's Avatar
I have all the original doc's and there wasn't anything included with it that has what you are looking for unfortunately. You might try posting on the Music-electronics-forum.com . Sorry I couldn't be more help.
Old 01-23-2018, 04:28 PM
Or Gearslutz.com.
DIGI 003 controller service manual. yamahadrums 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-11-2012 10:18 AM
I Need The Digi 002 Service Manual. (Repair guide for 002 Console) Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-25-2010 01:00 PM
service manual GabriMix General Discussion 0 11-11-2009 12:36 PM
Manual For DIGI Hardware GTBannah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-12-2008 02:29 AM
HUI Service manual needed jammanis Pro Tools TDM Systems (Mac) 1 08-01-2006 06:47 AM
