Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 08-23-2010, 08:03 PM
doppler58 doppler58 is offline
Default ProFire Lightbridge / Project Mix IO / Pro Fire 2626
Would it be possible to hook up a Project Mix IO as the master and two Pro Fire 2626's as slaves using the ProFire Lightbridge. If so are there any diagrams, instructions things I should know, if in fact such a set-up is possible.
Thanks,
Danny
Old 08-23-2010, 08:11 PM
pidge pidge is offline
Default Re: ProFire Lightbridge / Project Mix IO / Pro Fire 2626
Thanks,
Danny
no...
Old 08-23-2010, 09:08 PM
OK - Why not and what could you configure with these units...
Old 08-24-2010, 08:53 AM
edgarbc1 edgarbc1 is offline
Thanks,
Danny
if you have 2 pf2626, then why not just use those two, one as master and
one in standalone mode thru adat.. this is a known config which works, search the duc and maudio site for details
17" MBP i7, 4GB RAM, Profire 2626, PT-MP 8
Old 09-02-2010, 11:49 AM
tribedescribe tribedescribe is offline
You can also run the Project mix via firewire with 1 2626 in adat mode. You have no need for the lightbridge in your setup. FYI , m-Powered and le Pro tools are limited to 18 inputs.
Is the Profire 2626 more stable than Profire Lightbridge? (PT8 or snow leopard?) tomv-k Pro Tools M-Powered (Mac) 5 03-09-2012 02:45 PM
Profire 2626, Project Mix I/O, PT9 protools123 macOS 5 09-25-2011 11:57 AM
Driver Conflict ProFire 2626 and Project Mix doppler58 Pro Tools M-Powered (Mac) 1 10-06-2010 10:54 AM
Need Adivised : New 16 I/O System, ProFire LightBridge or 2626 with Aurora16 josephm Pro Tools M-Powered (Win) 4 10-30-2008 04:12 PM
m-audio Profire Lightbridge Vs. 2626 Andi Tips & Tricks 1 04-14-2008 11:45 AM
