Old 06-28-2009, 12:12 PM
SPC SPC is offline
Default Working With Avid Mojo - Avid QT LE Codecs
I freelance at 2 companies that use the Avid Mojo. One company uses the regular Avid Mojo and the other uses the Mojo SDI. I'll need to bring sessions worked on at these companies (on Pro Tools HD 7.4), home to my Pro Tools LE 8(with the DV TK2) system where I currently do not own a Mojo. At home, I simply use the Pro Tools movie window displayed onto a second large LCD monitor.
I thought I once saw that when I "saved session copy in..." from the Pro Tools HD/Mojo systems, that video format/codec was something way different than .mov or .dv. I believe it was .mxf which was not readable on my home system. So I'm trying to find a solution in order not to tell the Avid Editors to output as normal for the other 3 in-house audio guys, plus create some second file/pass of a Quicktime video for me and my home setup.
Thank you,
SPC
Old 06-28-2009, 12:54 PM
Craig F Craig F is offline
Default Re: Working With Avid Mojo
options:
find a deal on a used MOJO
I think there is a mxf plug-in out there for Quick Time
get a copy of Media Composer to convert the mxf to some other codec that QT can play
ask if they could use an Avid codec that is in the Avid codecs for QT (easiest way to get this would be to ask for a copy from the Avid install disk, [why is this not downloadable from the Digi web site])
Thank you,
Craig
Old 06-28-2009, 09:32 PM
hef hef is offline
have them make any quicktime for you and just convert it to the DV codec using QT pro or MPEG Streamclip. MPEG Streamclip is free.
Ryan Heiferman
Big Yellow Duck, Audio Post NYC
Mixer/Sound Designer
IMDB Credits
Old 07-05-2009, 06:12 PM
edboy7 edboy7 is offline
This might to the trick...Works for me from omf to Qt
Do a " bounce to quicktime" option..It will convert the omf video to QT. May take some time though
http://www.imdb.com/name/nm2585847/
PT Ultimate 2019 MAC WORKPLACE
PT Ultimate 2019 Windows 10 Pro HOME STUDIO
Less is More
Old 07-05-2009, 11:05 PM
CD Productions CD Productions is offline
It takes a very long time. But it does work.
Charles Dayton, CAS
Twisted Avocado Post Audio
http://www.imdb.com/name/nm0206743/
Old 07-06-2009, 01:50 AM
tj_davies tj_davies is offline
Does the bounce with conversion (with sound disabled) work faster? (press ctrl+alt+cmd while pressing bounce to quicktime)
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 07-06-2009, 08:57 PM
can we please get a link up in the stickies for the Avid QT codec download?
Thank you,
Craig
Old 07-22-2009, 02:41 PM
fenders fenders is offline
Default Re: Working With Avid Mojo - Avid QT LE Codecs
As the download link on avid.com seems to be broken: please try here
We use the AVID QT LE DV25 Codec with Mojo (looks much better than normal QT DV).
But we have 2 problems with it:
1. The tumbnails in Pro Tools timeline are all black.
2. The bigger problem is that, if I bounce to quicktime, the exported movie also is completely black, no matter what format I bounce to...
Can anyone confirm this behaviour?
best regards
______________________________________________
PT10 HD2 Icon D-Command - Mac Pro - SYNC I/O - OS X 10.8.5 +++ PT11 - RME HDSP 9652 - MC Control + Mix
HTML code is On
New AVID HD codecs soundboy35 Post - Surround - Video 1 07-30-2008 11:07 AM
New AVID HD codecs soundboy35 Post - Surround - Video 0 07-15-2008 11:22 AM
AVID MOJO / AVID XPRESS DV / PT 7.0 Questions Echo studios Post - Surround - Video 5 01-07-2006 12:06 AM
Avid Adrenaline to Avid Mojo uno1234 Post - Surround - Video 4 06-11-2005 07:11 AM
Avid Codecs OS9 Quicktime 6 Not Working seapea Post - Surround - Video 2 03-29-2004 09:59 PM
