Old 05-05-2009, 02:50 PM
elsterNJ elsterNJ is offline
Default Help!! Can't import the selected video file. (Pro Tools 8)
The file and file path do not contain any out of the ordinary characters such as \. It is a .wmv file. The error message that comes up is Can't import the selected video file because it does not contain any video frames. Using Pro Tools LE 8 on Windows XP. Have an Mbox2. Any suggestions?
Old 05-05-2009, 03:27 PM
sleadley sleadley is offline
Default Re: Help!! Can't import the selected video file. (Pro Tools 8)
Try converting a small part of the file to DV or MJPEG with http://www.squared5.com/svideo/mpeg-streamclip-win.html and see what happens.
This is a must have program for both Mac and PC. Best of all it is free.
hope this helps
Simon L.
Plan for the worst, Hope for the Best.
www.trackdown.com.au
Old 10-27-2010, 06:22 PM
tecuancho tecuancho is offline
Hi.
Well I had the same problem and I tried changing the name of the file and work fine now.
Ex:
Old name: BLOQUE 04 CAP 05 TC VISIBLE-DV NTSC 16/9 23.98.mov
New name: BLOQUE 04 CAP 05 TC VISIBLE-DV NTSC.mov
Pro Tools has big problems with Data and Metadata Names.
The metadata names contain (,./';!@#$%%^&*) and if the data name contain the this characters PT crash !
HTML code is On
Can't import the selected video anal-log 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-12-2010 01:34 PM
cannot import second video file! different frame rate message. crizdee Pro Tools TDM Systems (Mac) 6 10-14-2008 09:10 AM
IMPORT VIDEO ERROR Audio FILE alx002 Pro Tools TDM Systems (Mac) 1 10-01-2008 12:31 PM
ProTools HD 7.4 - Can't import video file. HELP!!!!!! jayprotools Pro Tools TDM Systems (Mac) 3 04-09-2008 05:16 PM
can't import video file into the session.... EminTR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-24-2007 09:24 AM
