I fell for the Bass Fingers plugin and it doesnt install ..
I am soo stupid as i promised to stop buying software a few years ago and only buy hardware.
Well dumb me bought Bass Fingers as it was 25 bucks which is nada!!! However I want to use it at my house on a Mac Pro 12 core 6.1 with Sierra and all the rest of the waves plugins I never use are V9 and Bass fingers V10. As per usual it just does not install Goes to approx 75-80% on the bar in waves central and then stops install. Tried since last night and still no bueno!!! WTAF is going on??? As it doesnt require my Gold bundle and api etc to be wuped why is it not installing?? Super glad for any ideas as this VI sounds great!
Re: I fell for the Bass Fingers plugin and it doesnt install ..
It should install V10 waveshell all by itself. Waves changed there setup in the last couple of months and i constantly get the "Your browser is not supported" message using IE. If so you can temporarily set up a different browser as default. I think the first thing i would try would be to uninstall Waves Central then reinstall the latest and try again.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro PT 2023.3 Studio through an A&H Qu-32 |
Sorry Chris cant help you but $25 gonna take a look.... thanks for the heads up.
Rob MBP 15 2018 macOS Big Sur 11.6.8 Touch Bar and ID 2.2GHz 6 core 8 gen Intel Core i7 processor (TBs to 4.1GHz) 32 Gb of 2400MHz DDR4, 1T SSD, Magic Mouse and Keyboard Pro Tools 2022.7 -23.# - HEAT applied, RME Fireface UCX II ........and a bowl of M&M's |
Youre right Chris this sounds awesome... just downloading it now..... geeez its huge at 21Gb Ill let it sit over night and do its thing. If I have any probs will let you know.
Thanks to both of you. I will try the idea 64GTO posted.
And Rob, please let me know if the install works for you. And what ersions of Waves OSX etc. You dont need to install both SD and HD files. They are the same both higher quality with the HD which is 15-16GB and the SD only 2.5GB Thanks again guys
Also keep in mind that when Waves does a W10 waveshell install it doesn't hose your W9 plugins - it's a known problem and I forget the remedy for it (other than wupping everything to W10). I fell victim to that last year and ended going the WUP route
They say that V9 and V10 can be coinstalled as long as its not the same plugins so as I dont wanna wup the plugins I have on my private nMP I kept that V9 and the Bass plugin is V10 but should work as it doesnt excist in V9 form.
The weird thing is it downloads to about 75-80% then the blue indicator bar just stops and only way to quit is to press stop button. Doesnt throw any error msgs or anything. Just stop loading and stays frozen.
Been tempted by this plugin but then again I have a real Jazz bass around here The one vi bass I like is the Rick bass from NI. The gui even has Lemmy's hat sitting on a chair. I bypass the internal amp in the plugin and go into either Bassdude from Plugin Alliance or the Ampeg B15 emulation in Amplitube 4. The Jazz bass get's di'd straight into PT. |
All my Waves plugs are V10..... and yup the install has been hung up for nearly an hour at the point in the image I posted below.... I have left it for a bit to see if it ebbs its way through but I think it wishful thinking.....
WOW! Thats EXACTLY what happens to my download and nothing is gonna happen further unfortunately. I tried installing onto the cloud option, the desktop and on a separate Thunderbolt3 SSD but no go. Both the HD stops there and the smaller 2.5 ish GB SD option stops there aswell something is wrong for sure with Waves servers or the download files on their servers.
I have sent a support ticket to waves so Rob, pls do the same and hopefully one of us gets an answer to this. Thanks a million for the update and picture. I am not happy but relieved that I am not crazy atleast
New Bass Fingers, for all you Bass Slapper fans | simon.a.billington | Virtual Instruments | 0 | 06-19-2019 05:37 AM |
First install of Pro Tools 9 - Logic 9 already installed - PlugIn install questions | b-pole | macOS | 2 | 08-31-2011 07:23 AM |
bass amp plugin- what do you use? | remis | General Discussion | 21 | 12-05-2010 08:25 PM |
Guitar/bass synthesizer Plugin ? | Jayoel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 01-26-2009 09:50 AM |
Bass Amp Simulator plugin | Matt Darcy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 02-16-2008 06:13 AM |
