Old 02-04-2011, 01:25 PM
megahurt megahurt is offline
Default > Please help with PT 'playback engine' settings
I'm struggling to get the right combination of settings in Pro Tools. I also can't seem to find a very detailed description of how to go about figuring out the optimal settings for my system. Hopefully someone can help.
Here's what I'm dealing with:
• Pro Tools HD 8 (8.0.4)
• Two expanded 192's (24 in, 24 out)
• HD Core card, 2 HD Process cards (connected via Magma expansion chassis)
• OS X 10.6.6
• Processor: 2 x 3 GHz Quad-Core Intel Xeon
• Memory: 16 GB 667 MHz DDR2 FB-DIMM
Here's a screenshot of the current settings:
http://postimage.org/image/1v2ehxgis/
I just want to make sure I have the correct settings to get the most out of the system.
Thanks.
Old 02-04-2011, 03:09 PM
maxon maxon is offline
Default Re: > Please help with PT 'playback engine' settings
looks good as default settings, only ignore errors during playback check off.
RECORDING Studio: Mac Pro, OSX 10.6.8, PT HD 3 PCIe, Pro Tools 8.1.1,
MIX + MASTERING Room: MAC Pro, OSX 10.6.8, PT HD 3 PCIe, PT 8.1
3x 192 I/O, Digidesign PRE, UAD Octo, UAD Satellite Ultimate
Old 02-04-2011, 08:26 PM
Andre Knecht Andre Knecht is offline
Additionally, I’d maximize the amount of RAM allocated to PT, by following the steps detailed in the first post on this thread…
http://duc.avid.com/showthread.php?t=293512
IHTH.
Andre Knecht
We’ll fix it in the shrink-wrap. (Frank Zappa)
Old 02-05-2011, 03:13 AM
Firechild Firechild is offline
I set RTAS processors to 5 (out of 8) and 512 samples latency.
4 DSP´s for 128 voices.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7
Old 02-05-2011, 07:30 AM
WernerF WernerF is offline
If you're using HEAT, which I know that the OP isn't with 8.0, you're most likely gonna have to max the voices to 192 as HEAT eats 'em up. These days I'm at 192 all of the time along with juggling resources such as RTAS vs TDM and de-activating unneeded aux's etc. just to get through a mix. This is on a system with five cards in a PE6R4.
Old 02-05-2011, 09:35 AM
JNS JNS is offline
Hi, Megahurt. Could you send me your email address, please? I have a question for you.
My email: [email protected]
Thanks,
Jeff
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24;
PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R
Playback Engine Settings russrags Windows 2 01-10-2014 05:23 AM
Help with Playback Engine Settings Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 08-28-2012 07:48 AM
playback engine settings qwertyuiop Pro Tools TDM Systems (Mac) 1 04-28-2011 03:52 PM
playback engine settings elcamino Pro Tools TDM Systems (Mac) 4 06-16-2005 11:34 AM
Playback engine settings smack Pro Tools TDM Systems (Mac) 5 10-12-1999 12:39 AM
