Old 07-04-2019, 12:56 PM
jamesleonard jamesleonard is offline
Default Re: iMac fans starting to get hot and very noisy again!
Don't need that over here in the UK, because, we are protected under: The Consumer Rights act 2015. Thats how I got the Flash Storage replaced for free.
Over here we are protected by the above law for six years.
so the only culprit possible is the graphics system.
Interesting... Why would you say that, what are the symptoms?
Everything seems to work and function correctly (videos, games, internet in general, etc.)
The fans only come on when the GUI is present onscreen. It is crazy!
Thanks
Old 07-04-2019, 01:55 PM
Originally Posted by jamesleonard View Post
Why would you say that (...) fans only come on when the GUI is present
1+1 usually equals 2
Old 07-04-2019, 02:29 PM
Well now...They are going to have to replace this, aren't they?
Speaking of which: I have always had a bad 'image persistence problem' with this iMac (see two attachments, after 10 minutes of exposure). YES that is image persistence!
When I first got this iMac, I complained at the time that it was not functioning as it should be.
Everything on this iMac needs to be addressed immediately!
I can’t work like this anymore and, it is becoming very difficult.
File Type: jpg E9DF2FCB-76F5-4395-8970-83DC766CF76E.jpg (24.2 KB, 0 views)
File Type: jpg BC8D4B4B-D7EC-42F4-883F-137F45AF2324.jpg (22.9 KB, 0 views)
Old 07-05-2019, 12:51 PM
I really need to ask this question - so forgive me for sounding like an idiot.
Would certain plug-ins in 'Pro Tools' contribute to the iMac fans generating HEAT and sounding like a vacuum cleaner?
Because... At this moment, the fans are *Blaring* and *Heat* is dissipating from the back-vent... Even though this process is happening, if I temporarily obscure the 'Pro Tools GUI' with a window (in this example: This very DUC page is completely obscuring the GUI), the fans will gradually quieten and the heat will cool. Eventually there is silence!
However, the moment the GUI window is visible onscreen - the fans start gradually cranking out the noise and heat... Until it is going 'full throttle'
It is 'absolutely mental' why this process - behaves like this - and causes this outcome.
Frankly, it is very worrying!
WHY? HOW?
Old 07-05-2019, 02:14 PM
Southsidemusic's Avatar
That is the weirdest issue I have heard in quite some time ...
Something has to be wrong inside somehow. Why would the DUC window produce more or less heat and fan noise than a PT window for example!?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 07-05-2019, 02:17 PM
Sorry that was a Typo... I meant GUI
I have corrected that, as of now.
In this example... I have used the DUC page as an example! It could literally be anything, any window, from any webpage. Even obscuring the Pro Tools GUI with the 'activity monitor window' will affect the fans.
See the two attachments: The first example is the Mix window onscreen (fans are extremely noisy and hot). The second example is the DUC window, in the process of completely 'obscuring' the mix window. (the fans will gradually 'die' down, when the Mix window is not seen onscreen)
File Type: jpg DUC_WINDOW_OBSCURING_GUI_MIX_WINDOW.jpg (48.2 KB, 0 views)
Old 07-05-2019, 02:39 PM
I am gonna ask avid tech guys if they heard of this and can offer some advice.sorry to hear you have this problem and as we have not seen this on the forum before it is hard to offer any thoughts that makes sense.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 07-05-2019, 03:03 PM
Thanks man. This problem has been very hard to explain.
EDIT//: I must emphasise that Pro Tools was playing on a continual loop - throughout every example - I have elaborated on.
Last edited by jamesleonard; 07-06-2019 at 05:31 AM. Reason: Pro Tools was playing a session in all examples
Old 07-05-2019, 03:28 PM
I bet! But lets try and see what these guys can offer us and I will post back here as soon as I have anything to post. I am gonna ask a few friends here aswell and they are tech wizards with insane knowledge
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 07-06-2019, 05:57 AM
In the mean time...
At the moment, PT is running through a session - and I have minimised the Edit window and Mix window to 'Dock' - iMac Fans are very, very quiet, almost non-existent and there is a slight, gentle 'trickle of air' filtering through the back vent. The back panels and stand are 'cool to the touch' - very nice! In fact: It is so tranquil and lovely...
But hold on a minute...! I have maximised the Edit and Mix window FROM the 'Dock' to ONSCREEN. Now, there is a furnace of hot air, bellowing, and thrusting out the back vent like some kind of 'industrial strength 'Flame-thrower' my room is now hotter and, I can feel myself starting to sweat profusely from the change in temperature. The back stand and panels now feel like 'they have just come out of a 'blacksmiths forge' I am now hot and irritable - and worried.
Time for this to happen (Cool to Hot): 1 Min
Last edited by jamesleonard; 07-06-2019 at 07:43 AM. Reason: This is no exaggeration
E6L Noisy with hdx fans AlainJRoy VENUE Live Sound Systems 1 08-30-2018 08:00 AM
Solution for noisy imac fans John_Toolbox Tips & Tricks 0 08-21-2013 01:19 PM
Noisy Fans james tebb VENUE Live Sound Systems 4 04-24-2009 08:26 AM
Noisy computer fans roman Tips & Tricks 7 08-30-2000 08:04 AM
Noisy Fans tsampson General Discussion 3 10-14-1998 08:35 PM
