  #21
Old 08-14-2019, 12:00 AM
themissingcow themissingcow is offline
Default Re: S3 + Mackie Control or HUI
Originally Posted by themissingcow View Post
I tried the 3.6.1 + 18.3 trick and the ports re-appear, but installing 19.7 over the top makes them disappear again (even if I don't un-install).
I just tried an experiment, and copied the EuphonixMIDI.plugin from the 18.3 install over the top of the one from 19.7 and now the ports show up. So this might be a work-around for those who need the update + MackieControl emulation. What I did was:
1. Install 3.6.1 then 18.3
2. Copy /Library/Audio/MIDI Drivers/EuphonixMIDI.plugin somewhere safe
3. Install 19.7
4. Copy EuphonixMIDI.plugin over the newly installed one
5. Restart
  #22
Old 08-21-2019, 06:49 AM
[email protected] morten@mortenhaugen.com is offline
I have Artist Mix up and running in Mackie Control mode with Reaper. The basic functions are working ok (faders, ON, Solo etc.), but the Solo buttons do not light up when pressed (as opposed to the On buttons which light when supposed to).
What could cause this, and how to fix?
  #23
Old 08-21-2019, 09:18 PM
EddieJones's Avatar
This would be on Reapers end...maybe not even implemented? Out of interest what OS are you one and what version of EUCON ?
  #24
Old 08-22-2019, 12:07 AM
Windows 10 64-bit, EUCON 19.5.1.
I see there's a new EUCON version out (19.7), will try that.
  #25
Old 08-22-2019, 09:51 AM
EddieJones's Avatar
Ah OK..Yes Windows works fine for Mackie Control...Its OSX that has the issues.
  #26
Old 09-01-2019, 03:07 AM
On the Avid Artist Mix control I can hold a shift button and touch a fader to reset it to default position (0 dB), similar to double clicking the fader with the mouse directly in Reaper. But the Avid Artist Mix sets the level to +2.94 dB instead of 0 dB.
Any ideas how to fix that?
  #27
Old 05-06-2022, 12:12 AM
mattrixx mattrixx is offline
Hi Eddie,
Just wondering. Did this ever get sorted out? I've never since been able to get MCU mode working. ie For something like RME Totalmix for example.
It's used to work a few years back and just curious if it works with MacOS now.
Cheers,
Matt
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
  #28
Old 05-06-2022, 08:45 AM
EddieJones's Avatar
Yes, this should work...but not all Mackie control is Mackie control, it doesn't take much for it to be broken if a command or two are not correct.
  #29
Old 06-23-2022, 10:33 AM
w00fa w00fa is offline
hi.
is anyone using the S3 with Live 11?
I've been using the Avid Artist Mix (black unit) in Live via MackieControl and am thinking of upgrading, but need to confirm that some functions are compatible. For example, on the Artist Mix in Ableton, the meters do not show and 'Auto-bank to selected track' doesn't work. Do they work on the S3 or are they implemented exactly the same as the Artist Mix, meaning that they will not work as well? Also, would these functions be Ableton's responsibility to implement?
best,
-w
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
Digi 003 Control Surface Mackie Control Mode ctmusicman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-23-2008 07:23 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
Can the Mackie Control extender work w/o Mackie Control? fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-03-2003 08:52 AM
a note from Mackie about the Mackie control remote Pro Tools TDM Systems (Mac) 100 11-02-2002 12:25 AM
