marker numbers - can they be automatically re-numbered?
Is there a better way to auto re-number markers other than the export - import midi trick?
Re: marker numbers - can they be automatically re-numbered?
Hey, Matt,
I don't know of any easy way to auto renumber the markers, but what's the export - import midi track? |
Click once in the marker ruler, select all, cut and paste... unless I don't understand what you want.
In the Marker Window you can change the number to something that is not taken. With a little planning, you can renumber them the way you want. Tedious. Slow. But it is a way to renumber a few. If you need to do a lot, then you need to do the export/import MIDI trick.
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
Nice tricks those. Do you have to use a midi track? Can you not just delete the markers and re-import them from the session-file you have open without saving over it before? Or will it only work via midi?
frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Thanks.
It only works with MIDI. If you import from another session, it retains the same number as the session of origin. Pity. Would be nice to have a feature that did this. But, to be honest, I do this so infrequently, the MIDI Export/Import trick is fine for me.
I thought this finally got added in the latest version but I can't find it.
They previewed this at NAMM, and I've heard rumors that it should be coming in the next release, but can't confirm that.
Scott Gatteño |
i heard they were doign update for markers - that might solve.
think they were also adding extra marker tracks which would be nice any hints on when that might land?
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive Focusrite Saffire PRO 40 Ultimate 2022 10 / HD Avid MC Mix / MC Control |
Keyboard shortcut for jumping from marker to marker... | shotgunndunn | macOS | 1 | 11-28-2012 07:45 AM |
Are PT's days numbered? | idris | Post - Surround - Video | 9 | 11-05-2010 09:52 PM |
Trying to set bar/beat marker, tempo marker won't conform | maitredebas | Pro Tools M-Powered (Win) | 0 | 07-31-2009 07:31 PM |
Just Curious...Why no numbered db scale on Channel Meters? | teacherman | Pro Tools TDM Systems (Mac) | 6 | 03-10-2008 06:10 AM |
First track not numbered "1" | mpetrie | Digidesign Hardware & Software | 1 | 11-06-1999 05:03 PM |
