D-Show system with power sequencer/relay system.
Hi, my theater is finally retiring our old Yamaha PM4000 and is currently in the process of purchasing a Venue D-Show System. Currently we have simple relay system that we use to power the PA on/off. It basically just turns on or shuts off the power to all our components in the correct order with the push of one button. I already assume that it is a bad idea to just cut power to the FOH rack but Im wondering if any ill affects can come about from cutting power from the Stage Rack. I plan on installing the stage rack in our amp room and it would be nice to not have to go in there any time I need to power the system on or off.
Thanks! |
Re: D-Show system with power sequencer/relay system.
You're correct that it's not recommended practice to simply cut power to the FOH Rack. Like most things computer-like it works best when shut down cleanly. Stage Racks are much simpler; you should have no problems power them on/off with a sequencer. Sheldon |
Thanks Sheldon! That is definitely handy info for our setup. I'm sure I'll be poking around more often once I actually start driving this thing on a daily basis.
Just got new D-Show system, some first try Q-s | digidesigner | VENUE Live Sound Systems | 12 | 08-15-2009 03:33 AM |
The power of a new LE system with PT 8 vs a mix system with PT6.4.1 | BGMusic | Pro Tools TDM Systems (Mac) | 4 | 10-08-2008 09:53 PM |
Mac system drive works ok but does not show | stevegalante | Pro Tools TDM Systems (Mac) | 1 | 06-06-2008 10:31 AM |
What is the D-Show Operating System built upon? | Lars Henning | VENUE Live Sound Systems | 4 | 04-22-2008 10:10 AM |
doesn't the system usage window show 2 cpu-bars? | der daniel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-06-2007 06:48 PM |
