Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 10-23-2019, 12:17 AM
b mcgibney b mcgibney is offline
Default Ozone 5 crashing PT 2019.5
This has just started. I did update from Sierra to High Sierra but not sure if it related. I thought it might be a random crash so I created a brand new session with one stereo audio track and one master fader. Nothing else. As soon as I tried to instantiate Ozone5 , Protools crashes. Sig file identifies the machine except that I am now running 10.13.3 High Sierra
What gives?
TIA Brian
2010 Mac 5,1 32 GB Ram. PT 2019.6. Mac OS 10.13.3 RME UFX and lots of noisemaking stuff
Old 10-23-2019, 03:20 AM
Audiofarm Audiofarm is online now
Default Re: Ozone 5 crashing PT 2019.5
Ozone 5? from 2012? Really?? Reinstall Sierra if you want to use it then.
Old 10-23-2019, 03:30 AM
JFreak's Avatar
JFreak JFreak is offline
Originally Posted by b mcgibney View Post
What gives?
You said it yourself; as soon as you instantiate your outdated plugin, PT crashes. Pretty sure nothing else is wrong except that. Update your plugin and expect to solve your mystery.
Janne
Old 10-23-2019, 08:25 PM
Well two things i found out today,
I have another ssd with the same OS and PT and Ozone works fine on that drive and furthermore numerous folks on the web claim to have no problem running ozone 5 in PT with High Sierra. The mystery deepens.
Brian
Old 10-23-2019, 09:36 PM
Well I correct myself again. I can open a session in high sierra that was made before I upgraded to high sierra and ozone runs fine. I just can't create new instantiations of OZONe 5. I threw a HD with Sierra and PT back in the machine and its works properly so I guess have to roll back. I have CCC so it should be ok. Getting near the end of the line for the old cheesgrater I guess....
Old 10-24-2019, 03:31 AM
JFreak's Avatar
Wouldn't it be easier to update the plugin?
Janne
Old 10-24-2019, 05:02 AM
What he said. Ozone 9 is $199 and probably cheaper being the OP already has Ozone 5. Login to your iZotope account and check it out. Not sure but I think you can have both versions of Ozone on the same machine - I know I have RX6 and RX7 on my cheesegrater in OSX 10.13.6
And update to OSX 10.13.6 via the combo updater.
Jack
QAPLA!
Old 10-24-2019, 07:45 PM
Izotope got back to me and confirmed Ozone Advanced 5 and High Sierra do not play together. Apparently some folks are having it work but it is not supported.
Well I reverted back to Sierra on one of my drives and mostly all good. On one of my High sierra drives and downloaded Ozone Advanced 9. That works fine. One of the things that always bugged me about post Ozone 5 was they got rid of the reverb which I quite liked. Also I have dozens of saved presets.
So moving on, for those who have used Ozone 5 and have moved to Ozone 9, is it worth it?. I'm now a pensioner and and just a hobbyist so it is all about spending my "mad money" as wisely as possible. Thanks everyone
Old 10-24-2019, 07:53 PM
sdelsolray sdelsolray is offline
Yeah, I didn't like the iZotope deleted the reverb module when going from Ozone 5 to Ozone 6. That being said, it was not the best reverb on the block by any measure.
Old 10-24-2019, 09:53 PM
Probably not but you could hear it in the context of everything else you were doing in the plug in
Updating from 2019 .5 to 2019.6? ihate100bees Pro Tools 2019 13 07-04-2019 09:30 AM
iZotope Ozone 8 and Neutron 2 Crashing Pro Tools. TOM@METRO AAX Plug-ins 14 03-31-2019 02:50 PM
Update for Ozone 5 and Ozone 5 Advanced gives Pro Tools 10 1 11-27-2011 09:02 PM
Izotope Ozone 3 crashing Pro Tools 7 pcombs Pro Tools TDM Systems (Mac) 3 01-15-2006 07:47 PM
