Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 10-17-2019, 04:18 PM
ebjazz ebjazz is offline
Default Error Message
Hi; I've been getting this message lately:
Could not complete the Bounce To Disk command because The filename, directory name, or volume label syntax is incorrect. (123) j:\AAA Master Tracks from J\Masters 16(available) E\Edits & full -wav\Tribal Melody
.wav
There are no illegal characters in the title. If I shorten the title to one letter it bounces, but anything longer and I get the message.
So I tried to delete the prefs and nothing worked so I restored them. I'm pretty sure that there are files in the folder that I'm not supposed to delete so I've attached a screen shot of the folder. Please tell me which files to delete.
Win 10
Eric Bolvin
Add horns to your project!!
http://www.bolvinmusic.com/horns-r-us.html
408.236.2009
Old 10-17-2019, 04:50 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Error Message
I think it's just the ProTools Prefs file. Can you post a screenshot of the error message?
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.6
Old 10-17-2019, 04:55 PM
I don't have a screen shot, but this is the message:
.wav
Eric Bolvin
408.236.2009
Old 10-18-2019, 04:48 AM
.wav
Win 10
I know in the past Windows had problems with spaces between characters and if you typed out the message correctly it looks like that could be the problem. That's why a lot of times you'll see underscores between characters where a space would be.
Jack
QAPLA!
Old 10-18-2019, 04:49 AM
JFreak's Avatar
JFreak JFreak is online now
j:\AAA Master Tracks from J\Masters 16(available) E\Edits & full -wav\Tribal Melody.wav
Before freaking out have you tried to bounce with a simpler name and rename later?
Janne
Old 10-18-2019, 07:54 AM
I am not a Windows user, so am not sure about this, but is it possible that the ( ) & in the directory path are illegal characters? Maybe try renaming your folders without those characters and see if that helps?
Scott Gatteño
Yessian
Old 10-18-2019, 10:00 AM
Those are not the problem. The problem/illegal characters are the slashes / \ and the colon :
See this page: https://gist.github.com/doctaphred/d...e1b7ddc02034d3
Jack
QAPLA!
Old 10-18-2019, 11:31 AM
JFreak's Avatar
Colon is a Mac character (not allowed) but used in Windows drive letters where it is allowed.
Slashes are forward on UNIX and backwards on backward systems (Windows)
Janne
Old 10-18-2019, 11:34 AM
The Weed's Avatar
The Weed The Weed is offline
It may not be the file name itself that's the issue, but how long the destination address is. Try bouncing to your C: drive's desktop and see if that works.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 10-18-2019, 11:39 AM
JFreak's Avatar
Didn't count but must be less than 100 characters. If there is a problem in Windows with names like that I need to find that facepalm emoji
Janne
Pro Tools 11 activation error-licensing service not running error message Seismic Sound Windows 5 03-23-2015 06:35 AM
error message DAE error-6006 tad3219 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-03-2011 08:17 PM
error message during installation error 2147213312 pianovasano Pro Tools M-Powered (Win) 1 08-31-2010 08:52 AM
Does anyone know what this error message means. ERROR DAE 9060 boabyd23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-18-2009 12:41 PM
A Message But Not An Error Message RichrdC Pro Tools M-Powered (Win) 3 01-27-2008 07:57 PM
