Old 10-01-2019, 08:28 AM
breakersrich breakersrich is offline
Default Click track file - pro tools 10 hd
i went to add a click track to a session in Pro Tools 10 and was able to.
after investigating it seems that im missing the click track plug in file. any one else experienced this?
does anyone have the file they can share?
Thanks
Old 10-01-2019, 10:28 AM
BScout BScout is offline
Default Re: Click track file - pro tools 10 hd
The click track is just an aux track with the click plugin inserted. It's really just a menu shortcut to adding that.
Anyone should be able to do that manually.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 10-01-2019, 01:51 PM
the plugin file is missing
Old 10-01-2019, 02:29 PM
Plugins do not often delete themselves from your computer.
The actual click plugin *file* is missing on your computer? You mean the RTAS? DSP or AAX plugin files? (I can’t recall what PT 10 exactly came with... and you are running TDM?). How/where did you look for that file? Do you see the plugin(s) load when you start Pro Tools? of the plugin is not showing up in pro Tools? What exact type of track are you using and where in the plugins menus are you looking for this.
Start by checking both plugin folder locations for Click plugins, and seeing if they are there that they load at startup.
Trash prefs and start with a new totally empty session and try adding a click track, then try doing it by hand if needed.
Old 10-01-2019, 02:51 PM
JFreak's Avatar
JFreak JFreak is offline
Originally Posted by breakersrich View Post
Thanks
Re-install the software and all missing files are copied where they should be.
Janne
Old 10-02-2019, 07:40 AM
Thanks i will try it
Click Track On Pro Tools SE barefootanarchist Pro Tools SE and Essential (Win) 0 07-30-2012 10:34 AM
click track using pro tools 7.4 tyrannosaurus frank Pro Tools M-Powered (Mac) 0 04-01-2008 09:40 PM
Click Track from an audio file in PT ??? nowinner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-07-2006 10:15 AM
Turning Click Track into Audio File Davey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-24-2005 04:03 AM
Click Track to Audio File Raw-Tracks Pro Tools TDM Systems (Mac) 3 07-07-2005 10:42 AM
