Old 09-28-2019, 07:17 PM
Default Re: Using automation to select presets in Reverb
Originally Posted by Ben Jenssen View Post
I don't think you can select plugin presets with automation. I'm still on PT10, so I don't know about newer versions.
That's why albee's suggestion of plugin bypass automation sounds wise.
And Janne's pointing to reading up on plugin parameter automation.
It's not so much a matter of what PT supports but what the plugin developer puts up for automation. Problem with plugin bypass automation means to me you're running several reverbs and if they're ir-based then you had better have serious cpu power.
I still come down on the side of artistic sense and what's listenable for long periods of time by many different people.
Jack
QAPLA!
Old 09-28-2019, 09:19 PM
BScout BScout is offline
You can't automate the plugin presets that belong to the Pro Tools window but there are some plugins like Exponential Audio's Nimbus where "Reverb Type" is automatable and you can take a snapshot of all parameters in automation thereby more or less freezing a preset to a section.
But overall, this is a bad idea. And I question any "music pro" who would even suggest it. Put the different reverbs on different auxes and then use multiple sends to automate sections to go to each reverb. Automating bypass is a bad idea for reverbs because you can create clicks when it goes in/out or chop off reverb tails.
Pro Tools Ult 2019.6, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
Old 09-29-2019, 02:32 AM
JFreak's Avatar
JFreak JFreak is offline
The context here is a session with several songs, having gaps between songs so no problem.
Janne
Old 09-29-2019, 04:42 PM
Another option for you; create several stereo AUX tracks and feed ALL of them with the same send/bus. Then either mute all these return AUX tracks, leaving the desired reverb track un-muted, or pull all the AUX track faders down and push up the one you want for each "segment" of the overall project.
The cool thing about digital is; there's 4 ways to do everything. The bad thing about digital is; there's 4 ways to......
Can't access Air Reverb presets dakotafletcher1721 Pro Tools 2018 0 11-05-2018 09:42 AM
reverb presets garimpo Post - Surround - Video 5 10-03-2008 08:09 AM
Are there any presets for the Reverb One? Imagine Pro Tools TDM Systems (Mac) 3 08-16-2004 01:12 PM
Reverb One Presets Jan Rooymans General Discussion 3 06-05-2002 02:09 AM
Reverb One presets Avid Pro Tools TDM Systems (Mac) 3 06-05-2002 01:01 AM
