  #31
Old 10-22-2019, 06:21 PM
unkJE unkJE is offline
Default Re: MDW Hi-Res Parametric EQ 5
Originally Posted by Peter Duemmler View Post
Yes and MDW EQ 5.0 (AAX DSP/NATIVE).
Peter
Are you using Pro Tools 2019.6?
You need to install the penultimate (last but one/second last) version of iLok License Manager, as there are problems with iLok’s latest version – see:
PT Restarts after Exiting, Endless Loop...?
http://duc.avid.com/showpost.php?p=2542241&postcount=10
Originally Posted by guitardom View Post
i believe if you download the newest, then extract it. In the folder structure is a "Old installers" folder
Pro Tools 2019.6/10.3.10 and 12.5.1 HD - Studio One 4 Pro - Win7 64 Ultimate (SP1) – Lenovo W520 ThinkPads & 433830U Docks – Mbox 3 Pro - Axiom Pro 49 - AIR Mini 32
  #32
Old 10-28-2019, 08:54 AM
Peter Duemmler Peter Duemmler is offline
Still doesn't work.
I'm not willing to install an old ILM, MDW should get their stuff together...
http://www.merlinsound.de
  #33
Old 10-28-2019, 05:04 PM
MDW Support's Avatar
MDW Support MDW Support is offline
Massenburg Design Works
MDW EQ5 works fine with the latest ILM (the post above referenced an issue with the host and the latest version of ILM).
Can you please contact us via our support portal and we can see what version of MDWEQ5 you have and take care of you.
https://massenburgdesignworks.com/contact-us/
Thanks,
Rail
Massenburg DesignWorks®
  #34
Old 10-30-2019, 02:03 AM
Tobias Eichelberg Tobias Eichelberg is offline
NOT working for me. I've tried multiple times, but when I install version 5.2.1r17 I keep getting the message "The following plugins failed to load because they are not valid 64bit AAX plugins: MDWEQ5-AAX-3B.aaxplugin, MDWEQ5-AAX-5B.aaxplugin".
I'm using the Native+DSP version of the plugin, running PT 2019.6.0 on OS X 10.13.6 with an HDX2 system.
I installed the latest iLok License Manager, also did the deactivate and reactivate license thing - not working. Stupid software!
Also - when I look at the plugins the above linked installer installs into the Pro Tools plugins folder, the creation date on those plugins is from 2014 - am I missing something here? Is version 5.2.1r17 created on the same day as 5.0.2r34?
  #35
Old 10-30-2019, 02:21 AM
UPDATE - the date issue was the hint.
Before you install version 5.2.1r17 be sure to DELETE the old plugin from your plugins folder, because the installer does not install properly over the previously installed version.
THEN it works.
  #36
Old 10-30-2019, 02:28 PM
We'll have a newer version where the installer deletes the previous one for you.
Thanks,
Rail
  #37
Old 10-31-2019, 05:29 AM
Johnny Hulst's Avatar
Johnny Hulst Johnny Hulst is offline
And were can I download the newer version ? Providing a link would be nice.
Johnny Hulst
Hulst Audio Engineering
MacPro (late 2013) 3ghz 8-core, 32gb Ram, 512gb SSD
1x Avid HDX & 1x UAD-2 Octo --> Sonnet Echo Express III-D
2x OWC PCI Express SSD (2TB) --> Sonnet Echo Express SE II
1x MTRX+MOM+1DA-card+SFP/LC module multimode 1300nm low output LED
4x 192 I/O (64 analog inputs)
1x HD Native Thunderbolt
Avid Artist Mix
Rupert Neve RNHP
http://www.hulst.nu
  #38
Old 11-05-2019, 06:32 AM
Instead of waiting for “a newer version where the installer deletes the previous one”, you could “carpe diem” on Mac OS X 10.7 or higher:
Delete the previous version – both the App & the AAX plug-in
Run CCleaner then CCleaner Registry then restart computer
Install iLok License Manager from within the Pro Tools 2019.6 Installer – my Windows version (5.0.3.2569) is located here: Pro_Tools_2019.6_Win\Pro Tools\ISSetupPrerequisites\PACE License Support
If necessary, do a Search for “ISSetupPrerequisites” to locate your Mac version.
In iLok License Manager, right-click on your License and choose “Deactivate”.
After the spinning beach ball has stopped, under the “Available” Licenses Tab, right-click on your License and choose “Activate”.
Once your License is back on your iLok, right-click on your iLok and choose “Synchronize”.
Install the macOS version you own - either:
DSP + Native Version:
https://1drv.ms/u/s!ApgArEWWsfnhh-81Xw47E5APj3o58w
or
Native Version:
https://1drv.ms/u/s!ApgArEWWsfnhh-82wHQKwC8rtPL0wg
  #39
Old 11-05-2019, 04:53 PM
This works – but there’s now an easier way:
Download and install the (just-released) iLok License Manager version 5.1.1
https://www.ilok.com/#!license-manager
  #40
Old 11-08-2019, 06:48 PM
After manually deleting the old version and installing the new it now works, thanx!
HTML code is On
WTB: MDW Hi Res Parametric EQ jsvalmont Buy & Sell 2 03-02-2018 11:14 PM
Go-to Parametric EQs PatriotsBiker AAX Plug-ins 47 06-08-2016 09:44 AM
MDW Hi-Res Parametric EQ v5 is now available Avid Technical Alerts 1 08-24-2012 01:55 PM
parametric output EQ krishkrasj VENUE Live Sound Systems 1 05-10-2010 01:48 PM
What is Q in a parametric? dummy20707 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-22-2002 09:03 PM
