Old 03-07-2014, 09:48 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Transfuser Tip
Here's a way I've been using Transfuser that I haven't seen mentioned much elsewhere. One of best features of Transfuser is that you can create of up 12 variations for each module you have installed. These can be triggered by assigned midi notes C1, C#1, D1...etc... that's the little keyboard on the lower left of the Transfuser screen. So, try this:
1. Instantiate Transfuser on an PT Instrument track
2. Create separate MIDI tracks underneath that for as many modules as you have active in Transfuser
3. On each module in Transfuser you can assign a MIDI input channel at the top left of the module. Set those.
4. Set the MIDI out of the MIDI tracks to route the MIDI of those tracks to the correct modules.
Now, the fun begins. Solo a module and click on C1 on the bottom right keyboard icon to play the main sequence for that module. Some of the included loops have variations already included. Some don't. Doesn't matter. You can use Mario to create new variations OR just edit the sequence screen to modify however you wish. To assign the modified sequence to a new MIDI note, just click where it says "copy" by the little keyboard, then click on the note where you want to save it, and then click on "save'. Do this for as many variations of that modules sequence as you wish up to 12 in all.
Now, draw or play in with your midi controller the notes to trigger the sequences in whatever order you wish. This will provide cool variations and take the "loopiness" out of the loops by providing interesting variations. You can also play with the MIDI trigger note lengths...use quarter notes, or half notes instead of whole notes or several measures. this can create interesting stop/stop or even stutter effects if you wish.
So if you have, say, 10 modules, and each has 10 variations, that's 10^10th power possible combinations. More than you could ever explore in a lifetime!
Using the MIDI tracks to trigger the modules this way gives you a lot more control over the entire sequence and when parts come in and out.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Dell XPS 435T/9000 Win-10 Pro 24gig RAM
IntelCore i7 CPU 920@2.67GHz
Pro Tools 2018.12
Focusrite Scarlett 8i6
Old 04-25-2014, 08:43 AM
JimmyM's Avatar
JimmyM JimmyM is offline
Default Re: Transfuser Tip
Hi Donald,
I'm new to Transfuser, somewhere on youtube I saw a tutorial from digidesign where you can drag and drop audio from the protools edit window into transfuser...
so far no luck for me...how can I make this happen..
tips are mostly welcome
Jimmy Makhaisingh
Producer Mix/Mastering Engineer
JimJam Studio
iMac (Retina 5K, 27-inch, Late 2015)
PT11HD
HDX /HD i/o
Magma Thunderbolt 2.0 Chasis 3T
Manley Vari-Mu / MPassive Mastering version
Sonnox bundle / McDsp / FabFilter /
Old 04-25-2014, 08:54 AM
DonaldM's Avatar
Originally Posted by JimmyM View Post
Hi Donald,
Hi Jimmy. With Pro Tools 11, the drag and drop directly into the AIR VI's (Transfuser, Structure) is gone. It worked prior because in RTAS they were able to exploit some system problems to make that work. With AAX, that is no longer the case...at least that's how it was all explained in an article I read a while back. With 11, select the clip you want to import into Transfuser (or Structure) and give it a name that makes sense. Right click on the clip name in the clip list on the right side of the edit window in PT and export that clip...probably export as WAV...but that's up to you. I'd suggest you create a separate file on your drive to save these sorts of clips to find them easily later and then save ALL of them in that file as you create them. Once exported and saved, go to Transfuser, browse your hard drive to the file you just created and you should be able to drag and drop it over from the Transfuser list. Rinse and repeat for as many clips as you wish and/or to import into Structure.
I know it seems like a lot of extra steps but remember, AAX is much more stable platform, so losing the immediate drag and drop is not necessarily a negative. Secondly, though, by exporting clips to a file, you begin to build your own little library of clips and don't have to hunt around every time, which in the long run will save you some time.
Hope that helps, and good luck!
Pro Tools 2018.12
Old 04-26-2014, 09:46 AM
JimmyM's Avatar
Hi Donald thanks for your reply. Gonna dig into that's upcoming days
Jimmy Makhaisingh
JimJam Studio
PT11HD
HDX /HD i/o
Old 04-26-2014, 09:48 AM
Raoul23 Raoul23 is offline
Never used transfuser but think I will after this little tutorial thanks Donald :)
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 04-26-2014, 12:34 PM
DonaldM's Avatar
Careful Raoul - Once you get started, you may not emerge for days! Stockpile some survival food!
Pro Tools 2018.12
Old 04-27-2014, 07:59 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Ps
Don't forget that holding shift control lets you assign multiples out from one midi track.
I.e. If all you moded modules on different midi channels although separate clips on separate tracks is more flexible for placements variations.
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.10 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MacVCEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
Old 04-27-2014, 08:22 PM
DonaldM's Avatar
Originally Posted by DetroitT View Post
Ps
I'm not sure what you're trying to say? Can you say that in a different way? Thanks.
Pro Tools 2018.12
Old 04-28-2014, 11:00 AM
DetroitT's Avatar
No so much for changing your nice layout but doubling up sets of 12 or doubling outs to other modules.
Say one MIDI track goes out to Midi Ch 1. If you hold the shift plus control keys you can append/select another midi channel or device.
i.e. Midi track out to Midi ch 1 and 2
This also works for audio outs,
(MP 5,1 / 64-Gb)
Old 04-28-2014, 11:05 AM
DonaldM's Avatar
Right. I kinda thought that's what you meant, but wasn't sure. Of course doing that provides more variables. I was trying to keep it a bit more simple.
Pro Tools 2018.12
Transfuser DragonBlight Virtual Instruments 4 04-03-2010 02:29 PM
transfuser x 2 mafiacondon Virtual Instruments 10 03-05-2010 03:17 PM
installing Transfuser full on Transfuser trial wfasano Virtual Instruments 2 06-30-2009 04:14 AM
Transfuser V1.5? Mason00 Virtual Instruments 2 04-09-2009 08:49 AM
transfuser/ geeball Virtual Instruments 0 02-08-2009 10:05 PM
