Old 03-05-2012, 09:57 PM
PYROAZMB PYROAZMB is offline
Default Playback only out of left side
I apologize if this has already been brought up, but i am having difficulty findin out the problem. I have pro tools mp9 with a delta 44 interface and a mackie mixer. Everything is hooked up and running properly. Pro tools is detecting my mic sound and recording. When i playback the beat or whatever i just recorded, i can only hear it out of the left head phone. Does anyone know the problem.. im going crazy! lol
Old 03-05-2012, 11:40 PM
zedhed's Avatar
zedhed zedhed is offline
Default Re: Playback only out of left side
If you are using stereo track/s, is the signal showing on both L&R channels in the strip meter?
Also have a look at Setup>I/O>Output tab and make sure everything is set properly, and default output to Main L/R.
If you can, get hold of another pair of headphones to see if same problem exists. Same with cables.
Sorting this type of problem requires a process of elimination. Start at the beginning of the signal and test each junction in the signal chain.
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
[IMG] code is Off
Only hear left side of headphones sma5jp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-23-2010 05:20 PM
I only get sound out of left side of headphones msgood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-21-2009 08:16 AM
Left side of monitor goes out Bellboy ICON & C|24 1 05-25-2007 05:52 PM
002rack left side 3db louder than right Greg M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-10-2005 07:08 AM
001 Out levels Left side hot? ajazzie 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-30-2003 09:12 PM
