Old 05-01-2008, 08:15 AM
Greene Greene is offline
Default How to set up cue mix for control 24 and 192
How can i set these up? headphone amp for cue mix? I dont want to go control 24 aux out because it effects the whole mix.
Old 11-01-2008, 06:32 PM
Hamacek Hamacek is offline
Default Re: How to set up cue mix for control 24 and 192
Just wrote a detailed post on this elsewhere, then deleted it
Basically, go out of your 192 (not your main outs) into the ctrl24 aux in L&R, then ctrl24 aux out L&R to your headphone mixer (do you have one?).
Make sure 'main monitor to aux' (I think that's what it's called) on the front panel is NOT selected.
Create a cue mix using a send on the channels you want in the headphone mix going to the appropriate hardware, i.e. 192 outputs that you chose earlier. Make these all pre fade and mix away! You can of course select the send on your C24 and hit flip for quicker headphone mixing.
You can then control the overall cue level with the monitor to aux level control.
Hope this helps!
Hammers.
Avid Digidesign Control|24 and Sterling Modular Desk Console for Control 24-Separate relaxo Buy & Sell 3 09-05-2013 07:05 AM
How to control plugins applied to audio files with Artist Control ozu Artist Series 3 04-01-2013 02:36 AM
Control Surface For Protools 10 Mackie Pro Control or Avid Artist Control lberrios1962 Pro Tools 10 18 05-26-2012 12:51 AM
D-Control Es32 Control Surface No Sound from Headphone outputs mark007 Pro Tools TDM Systems (Mac) 0 02-08-2012 07:03 PM
Mackie Control Universal or Tascam 1082 for control surface? anders Pro Tools TDM Systems (Mac) 5 05-28-2007 06:12 AM
