Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-24-2021, 09:35 PM
Goombot Goombot is offline
Default MTRX Studio Audio Midi Setup
Is there any reason why the MTRX studio is not showing up in the Mac Audio Midi Setup app? Everything else I have plugged in and hooked up shows up.
Old 02-24-2021, 09:48 PM
LukeHoward LukeHoward is offline
Default Re: MTRX Studio Audio Midi Setup
https://avid.secure.force.com/pkb/ar...e-Audio-on-Mac
might help –*the device also won't be visible if Pro Tools is running
https://lukehoward.com/
Old 02-24-2021, 09:57 PM
ProTools isn’t open.
Old 02-25-2021, 04:09 AM
ntp-jl's Avatar
ntp-jl ntp-jl is offline
The MTRX Studio will not show up in Audio MIDI Setup as it is not connected directly to the Mac.
You should see your HD Native or HDX interface, or Dante Virtual Soundcard (if you use that), but the Mac can not see what is on "the other side" of those interfaces.
Jan Lykke
Business Development Manager
DAD - Digital Audio Denmark
Old 02-25-2021, 08:02 AM
That’s what I figured. Thanks
Old 02-25-2021, 08:19 AM
creativecontrol's Avatar
If you click Configure Device from your HDX, HDN or HDNTB device in Audio MIDI Setup > Audio with Pro Tools quit - it will launch the hardware setup dialog which allows access to buffers and crosspatching and will also show the peripheral name.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-25-2021, 08:35 AM
Does this apply for the MTRX studio in any way? Basically I'm trying to setup an aggregate device so I can print my re-renders from the Dolby Atmos Production Suite back into ProTools. Can I set up the aggregate with just the DVS and the Dolby Bridge?
Advice on MTRX Studio setup please Cheesehead Pro Tools | MTRX & MTRX Studio 9 09-03-2020 03:01 AM
MTRX Studio to Mac Core Audio? Cheesehead Pro Tools | MTRX & MTRX Studio 10 08-31-2020 04:59 PM
Multiple MBox Pro Instances/Icons in Audio MIDI Setup -> MIDI Studio lpeckham macOS 8 04-24-2014 06:39 AM
003 midi ports not there in midi studio setup? Unable to record midi now? TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-22-2009 12:06 AM
M-Audio Projectmix and PT 8.xx and Midi Studio Setup djtorch Pro Tools M-Powered (Mac) 0 11-24-2009 09:58 AM
