  #31
Old 01-08-2020, 12:03 PM
MikeReganNoise MikeReganNoise is offline
Default Re: Bug in new video engine 2019.10
Running Sierra 10.12.6 and PT 2019.10. This looping issue has been incessant for me all week on a job, using an 80 minute ProRes Proxy file. I didn't have this issue with the previous version 2019.6 so am planning to revert back. Won't be going to 2019.12 and am unable because I don't want to mess with an upgrade to AFPS and Mojave at the moment. It's honestly a bummer as I've been shelling out that $399/year to Avid for the upgrade and support plan, which I am happy to do if things improve but each new version has gotten worse since 2019.6
  #32
Old 01-08-2020, 12:12 PM
gwhatley's Avatar
gwhatley gwhatley is offline
I'm on Mojave and suffer with this same video looping bug. While it can be "defeated" in the moment by toggling the blue "video online" button on the video track, I cannot find a way to make it stop happening, nor any kind of commonality (codec, length of loop, version of Blackmagic Desktop Video) to try to counteract it.
My client stage is on 2019.5 so I don't have to worry about it with people in the room, at least.
Any insight, however small, from anyone would be appreciated.
Sent from my LG-H872 using Tapatalk
Garrard Whatley
Seismic Post Audio
Post Audio for Film and Television
System/Hardware Info
IMDb credits
  #33
Old 01-20-2020, 11:24 AM
tklaavo tklaavo is offline
This got very bad today using Aja T-Tap. It kept looping a one-second clip, no matter what I tried (disable / re-enable video engine or just taking the video track offline for a while have always been the cure before)
I removed the AJA box and plugged the HDMI straight to the trashcan, running as 3rd monitor desktop video in full screen mode. No more loops, but jerky playback.
This was with PT Ultimate 19.12, High Sierra. We downgraded all workstations to PT 19.6 today because we also had issues with the "referencing wrong audio" bug and check if this works better.
Tuomas Klaavo
Helea Sound Post Production Oy
  #34
Old 01-27-2020, 06:12 AM
BenZenium BenZenium is offline
Having the same issue. Had it in 2019.10 and still having it in 2019.12 on Mojave with Decklink 4k.
VERY frustrating!
  #35
Old 03-05-2020, 03:26 PM
brendan_hill brendan_hill is offline
Anyone found a solution to this? Happens so frequently that it really puts a stop in my workflow.
I can't update to latest version of PT yet either as the mixer I edit for is still using an older version that doesn't like opening the files (had updated then needed to revert back).
  #36
Old 03-06-2020, 03:08 AM
No issues of the sort here. (see signature for specs). Could be an old video card driver?
Note that 19.12 is only qualified with:
10.13.6, 10.14.6, 10.15.1, 10.15.2
F.
  #37
Old 03-06-2020, 10:26 AM
gwhatley's Avatar
Found no solution, just ways to "handle it":
(1) If a client is in the room, I DISENGAGE LOOP PLAYBACK. The looping bug does not occur. Any "looping" I need, I do so manually by making a selection and pressing the spacebar as needed.
(2) put "command+shift+J" *twice* in your muscle memory, which toggles video online off then back on, which defeats the looping bug.
Any other "quick tricks" out there until they find a fix?
Garrard Whatley
Seismic Post Audio
IMDb credits
  #38
Old 03-06-2020, 11:07 AM
the19thbear the19thbear is offline
I have problems with the new newest pt version on windows.(non hd).
If I import a video and put a sound somewhere on the timeline, all is in sync when I export a QT.
If I then get a new video and replace the old one with that, everything is out of sync when I play back and export.
Every time I get a new video, I have to make a new project and import everything into the new session.
I really wish they would work on their video engine.
It has always been super unstable.
  #39
Old 03-22-2020, 01:10 PM
zoing123 zoing123 is offline
Another BUG "Avid video engine stopped unexpectedly" 2019.12 happens often while editing fast. Its what we get paid for. I cant dictate to my clients what format they work in or send me. The video enging nightmare continues. Why should I take expensive time to convert to a file that Avid/pero tools is happy with. If I must what is best pro video converted for us heathen audio pros??
high Sierra/macpro.
Dick Maitland C.A.S.
  #40
Old 03-22-2020, 01:21 PM
gwhatley's Avatar
high Sierra/macpro.
Do you have "loop Playback" engaged? If so, even if part of your workflow, try disengaging.
If not, then I haven't run into this issue yet. If it is codec, a very fast converter is ffWorks - uses multiple cores, I've been very happy with it for feature-length projects, and it does short form super fast.
Garrard Whatley
Seismic Post Audio
IMDb credits
HTML code is On
'The Video Engine reported and error' message when trying to play any video zerothrills Pro Tools 12 10 02-28-2022 04:04 AM
Problem enabling video engine 2019.6 Lydbildet Windows 12 04-02-2020 10:24 AM
PT 2019 same video problems garnoil Pro Tools 2019 12 05-12-2019 03:50 PM
Video Engine Fail "Waiting for the video engine to launch" oscar_wonderboy macOS 5 08-14-2018 01:22 AM
Video Engine not working.. crashing when i load in a video to PT11 sarahsherlock Pro Tools 11 5 08-16-2014 12:35 AM
