Old 12-26-2018, 09:55 AM
littlesicily littlesicily is offline
Default New MacMini(i7), Mojave, PT 2018.12U, HD-Native
Hi All,
I know.... not supported yet, but a friend is successfully running the new Mac mini/Mojave/PT2018.12U ... with HDX.
I'm trying today w/ HD-Native Thunderbolt.... and I can't get Pro Tools to see my HD-Native and connected HD I/O's. I've unistalled/reinstalled, trashed prefs, restarted, etc. Btw, I'm using the Apple TB2-TB3 adaptor, which seems fine with all my other external TB HD's and such.
Anyone running this combo w/ HD-Native TB?
PT Ultimate 2023.06, Mac Studio Max M2 64GB RAM, HDX, OSX 13.04.01, EuControl 2023.06 w/ Avid S1
Old 12-26-2018, 11:53 AM
Southsidemusic's Avatar
Default Re: New MacMini(i7), Mojave, PT 2018.12U, HD-Native
Do you have the digilink license on your ilok key?
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-26-2018, 11:57 AM
Yes.
I still have my Trashcan Mac Pro and everything is fully functional on that rig.
On the Mac mini, I installed PT, HD Driver, rebooted, uninstalled, reinstalled, etc.
Still not recognizing the HD-N.
Old 12-26-2018, 12:04 PM
Just a quick question: why are you using a TB 2/3 adapter? The Native TB boxes are not TB3 and the trashcan connections are TB2 so try skipping the adapter and see if that does anything.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 12-26-2018, 12:07 PM
I'm using the TB2/3 adapter with the new Mac Mini, not the Trashcan. MacMini has TB3, HD-Native is TB2.
Old 12-26-2018, 12:15 PM
Are you sure the Thunderbolt box is TB2 as I have not seen that stated anywhere. It only say ”Thunderbolt” connection in all the articles and spec’s so maybe you need a TB3 to TB1 adapter if that exist.
You have done the PRAM reset and tested the TB cable so it works as it should? It is a weird issue but check on the TB1 to TB3 if the adapter you have is going to work with that connection.
HD Native Thunderbolt is a few years old and I am quite sure it is only TB1 on those boxes but as I said please double check that.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 12-26-2018, 12:39 PM
Yes, for the adapter... "The Thunderbolt 3 (USB-C) to Thunderbolt 2 Adapter lets you connect Thunderbolt and Thunderbolt 2 devices..."
Tried several different TB3 ports, two diff adapters and cables.
Old 12-26-2018, 12:42 PM
Lets make progress here. The Thunderbolt adapter will be fine, it it's known to work with other devices. Thunderbolt 1 or 2 does not matter, Thunderbolt 1 is a trivial subset of Thunderbolt 2 capabilities.
So really useful info would be how exactly is this not working. Does the device show up in...
System Report>Thunderbolt
Audio Midi Settings?
Digitest?
Playback Engine settings?
Confirm you are installing 2018.12 (we don't' care what your friend installed).
I can't recall what Mojave throws up for HD driver security approvals but make sure you have not missed any in Systems Preferences>Security & Privacy permissions when you run the installer again.
Old 12-26-2018, 12:59 PM
Digitest?
Thanks, Darryl.
System Report>Thunderbolt. YES
Audio Midi Settings? NO
Digitest? NO
Playback Engine settings? NO
Yes 2018.12
Not sure about security permissions. Nothing popped up when installing the HD driver.
Old 12-26-2018, 01:09 PM
Again I can't remember what driver warnings you should expect, but driver not installing because of security issues is a likely reason for this... or at least all you are seeing says the device is there and the driver did not install.
Reinstall that and watch out for dialog pop-ups hidden behind other Windows. And check Systems References > Privacy & Security for warnings... which disappear from there some time after any failed install. Rerun the install to regenerate them.
You will have to additionally enable mic inputs in Privacy & Security for the interface once it is working.
ProTools 2018.4 Ultimate and macOS Mojave BillDog793 Pro Tools 2018 121 03-07-2019 04:37 AM
PT 2018.7 on MacOS 10.14 Mojave works for me veinticinco Pro Tools 2018 38 12-09-2018 07:35 AM
2018.10 works on MBP i9 with Vega 20 and Mojave DarkandKurious Pro Tools 2018 3 11-27-2018 12:23 PM
