M-Powered 8 won't open all of the sudden.
I bought M-Powered 8 and a ProFire 610 a month ago, and up until yesterday, it all worked flawless. Now when I click on the M-Powered icon in my iMac Dock (I'm running Snow Leopard) to open Pro Tools, the icon will just bounce up and down for a minute then just stop without anything opening. I tried going through all the troubleshooting tips stickies at the top of this forum, but it still hasn't helped. I have the error report, but I don't know exactly what I'm looking at to tell me what the problem is:
Date/Time: 2010-02-23 00:29:51 -0500 OS Version: 10.6.2 (Build 10C540) Architecture: x86_64 Report Version: 6 Command: Pro Tools M-Powered Path: /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/MacOS/Pro Tools M-Powered Version: 8.0.3 (8.0.3f249) Parent: launchd [98] PID: 174 Event: hang Duration: 5.51s (sampling started after 2 seconds) Steps: 35 (100ms sampling interval) Pageins: 370 Pageouts: 0 Process: Pro Tools M-Powered [174] Path: /Applications/Digidesign/Pro Tools/Pro Tools M-Powered.app/Contents/MacOS/Pro Tools M-Powered UID: 501 Process: AirPort Base Station Agent [133] Path: /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent UID: 501 |
Re: M-Powered 8 won't open all of the sudden.
Do you have automatic updates on with the imac?
John Pro Tools 12.5 Macbook Pro & Windows 7 Ultimate 64 Bit |
I'm not sure, where do I go to check?
Go to the apple icon top left corner of your screen, system preferences then click on software updates and uncheck "automatically update" or something like that. I don't have my mac turn on at the moment.
Ok I found it and turned off the automatic updates. I currently have uninstalled M-Powered, so what's the next step, reinstalling it and seeing if it opens? Another question, when I do the install, it asks if I want to install the Digi IO driver, should I install that too even though I use a M-Audio ProFire as my interface?
I would install the IO driver. Have the m-audio device ready incase PT wants you to hook it up while pt installs.
Well I reinstalled it, and same thing happened. The icon will bounce for a minute then stop, and that's it. I'm starting to get a little worried now. I have a program called AppDelete that I can delete all traces of Pro Tools and Digi from my computer, should I use that to erase everything and reinstall it all like I was starting from the beginning?
If you used the software update and your system updated, then you will need to go out to apple and download the combo update for whatever version of MAC OS X you have upgraded to. For example if you are at 10.6.2 then you need to download and install this;
http://support.apple.com/kb/DL959 Hopefully that should fix your bouncing icon.
Pro Tools, Studio One Pro 2022 Mac Studio M1 Max 64GB-1TB NVME OWC Thunderbay Mini (4TB SSD) OWC Express 4M2 (4 X 2TB) Interface: Presonus Quantum Presonus Faderport & Faderport 8 Black Lion Sparrow Mk2 A/D, FMR-RNP-RNC, MIDI Xpress 128 BM5A, KRK VXT4, Equator D5 2020 Macbook Pro 16GB RAM, 512GB SSD Audio(mobile rig) |
I checked my list of what I had installed on Snow Leopard, and I already had installed that update. ^^^
Bradch00 maybe right on this. Go to his link and download the combo update and apply it your OS as appending updates won't work with PT. I just discussed this on another thread with another user and they downloaded the combo update and viola it works for them. So I 2nd Bradch00 suggestion. EDIT: Even though you may show you're already running 10.6.2 doesn't mean that is was applied by the combo update. THIS IS REALLY IMPORTANT THAT IT IS APPLIED THIS WAY. When Digi announced this years back they meant it.
Open PT9 sessions in PT9 M-Powered? | SixChurchStreet | Pro Tools 9 | 3 | 02-26-2012 08:50 AM |
PT9 M Powered Open? | levistripes | Pro Tools M-Powered (Win) | 11 | 09-03-2011 11:50 PM |
All of a sudden my projects won't open and I get a warning | The dman | Pro Tools 9 | 1 | 12-21-2010 11:20 AM |
m-powered n le can't open | KMK | Pro Tools M-Powered (Mac) | 0 | 04-05-2007 09:02 AM |
Can't open session on PT 7 M powered | Media Man | Pro Tools M-Powered (Win) | 1 | 05-23-2006 10:53 AM |
