Is it possible on Windows 10? multiple interfaces
I don't know if this is in the right forum and don't know if its possible in windows 10, but I have an old Digi 003 that I wanted to connect to my Audient ID44 to possibly use the other 8 inputs from time to time and I love my headphones playback better on the Digi 003 then the ID44. Is there anybody that connects the interfaces together in windows with success? I have Optical cords since both interfaces do have that but let me know if its possible.
Re: Is it possible on Windows 10? multiple interfaces
Aggregating is not possible with Pro Tools on Windows.
I use a Behringer ADA 8000 connected to my Digi002 Rack via lightpipe (fiber optic cable) to gain an additional 8 inputs. I bought it used for $125 years ago. I think they have a newer model available now.
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit. |
The newer one is supposed to sound pretty good, too!!!
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Indeed. The Behringer ADA8200(the red version) uses the newer Midas-designed preamps from the X32 and is easily as good sounding as the 002/003(probably much better than 002). There are several other lightpipe options at higher prices, the killer one being the Midas XL48(tracking drums thru that beat out several boutique preamps for me).
If you do decide to go the route of the ADA8200 or find a used ADA8000, be aware that The A/D converters are likely to be a few samples faster than your DIgi003's converters. So you may need to shift the audio recorded thru the ADA8200 forward in time to match the audio recorded thru your Digi003. I found this out by recording a snare drum thru both units onto 2 separate audio tracks, then zooming in to the sample level resolution and looking at the transients from the 2 audio tracks and seeing how many samples they differed. I think mine was something like 12 samples.
Another thing with the Behringer units is they can only use 44.1 or 48k sample rates, nothing higher. Not a problem for me as I record at 48k.
So it can be done but only if using the ADA8200 or 8000. So that ASIO4All doesn't allow me to use what I got? Or using a lightpipe won't connect my 2 interfaces to be used together. But the ADA8200 will allow it to work together.
Thanks for the many responses. |
That's right. The ADAs aren't an interface. Just think of it as an extra 8 mic preamps that your ProTools interface can receive and pass the signal thru to your computer.
To be clear, you can use any 8 mic pre to ADAT product, it doesn't have to be the two mentioned. But, you should also be able to use ADAT between the ID44 and the 003. That said, Pro Tools will only see one of them. On Windows, you can't plug both of them into your computer and expect Pro Tools to see both of them at the same time.
Multiple interfaces | Rockem48 | Pro Tools 12 | 0 | 06-04-2018 10:25 AM |
Multiple interfaces | Julia B | Pro Tools M-Powered (Win) | 3 | 06-22-2011 08:07 PM |
PT 9 and Multiple Interfaces | mhelm01 | Pro Tools 9 | 25 | 12-03-2010 08:46 AM |
Multiple interfaces??? | Bass1968 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-06-2007 09:20 PM |
AES/EBU on multiple 96 interfaces | Robin Reumers | Pro Tools TDM Systems (Mac) | 0 | 10-12-2006 09:41 AM |
