Old 11-13-2019, 12:09 AM
CarterFischer CarterFischer is offline
Default Plugin Control Automation Enable Preference Not Working
Hey guys and gals,
I've got a minor, yet annoying problem with one of my Preferences. I'm running Pro Tools Ultimate 2019.6 and I recently decided to re-check the Automation preference called "Plug-in Controls Default to Auto-Enabled." But, even after closing and reopening my session, the plugin parameters are still not Auto-Enabled. I'm either having to Cont+Opt+Com+Click them and choose it that way, or even actually go into the automation menu on some plugins and select which parameters to enable for automation. I've never had this problem before -- Any thoughts? I can't think of what would be causing this, and it's very annoying.
Thanks,
Carter
Old 11-13-2019, 05:25 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Plugin Control Automation Enable Preference Not Working
IIRC, this Preference will only work with any new plug-ins added to a session after the Preference is checked. It won't apply to any plug-ins already in a session.
AFAIK, it also applies to any plug-ins in a Template.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 11-14-2019, 10:06 PM
Ah, yes, well that makes sense. I appreciate the reply -- I thought I was losing my mind, lol.
Old 04-14-2020, 07:59 PM
rosshc44 rosshc44 is offline
Hey, just reopening this old topic. I seem to remember this preference working to toggle plugin automation enables as described in the original post in PT10 HD. What is the best way to enable all plugin parameters for automation in a session with plugins already on tracks in pro tools 2020?
Thanks!
Enable automation of a parameter for multiple instances of the same plugin. ReverbHead Pro Tools 2018 5 05-18-2018 10:04 AM
Automation Mode Workflow change (or preference) docric Avid S1, S3, Dock and Control App 12 09-01-2016 07:23 PM
Mackie Control HUI automation not working? rdolmat Pro Tools TDM Systems (Mac) 6 01-16-2009 02:02 PM
SRC preference not working mr.armadillo Pro Tools TDM Systems (Mac) 5 01-30-2007 04:53 AM
Enable automation from plugin interface? Mark 66 Pro Tools TDM Systems (Mac) 2 12-16-2004 10:58 PM
