  #5111
Old 01-19-2013, 12:42 PM
Default Re: i7 Builds - Specs and Results
Originally Posted by actualsizeaudio View Post
Cool, I was strongly considering the 3930K.
With 16gig of ram, if I'm keeping my RAM disk cache too high, then could that be causing an issue with plug-ins running out of RAM? I never thought of plugs being dependent on RAM. I often have the disk cache set at 10 or 12 gigs.
Thanks for the input.
Yes plugins take a certain amount of ram. Some far more than others. Disk cache is not going to affect what you have available to the system, PT, and plugins as the available cache amount is 4gb under your total for exactly that reason. If you are running vi's they will eat up your ram really fast and bog your system down.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
  #5112
Old 01-19-2013, 12:44 PM
Originally Posted by mykhal c View Post
i'm sure PT11 will bring about even better core usage but it ain't too bad right now. once i unparked my cores the load was then evenly spread across all cores, physical and virtual. if you don't unpark the cores then the load will always go to the physical cores first. i've yet to run any tests to see which is actually more efficient for PT.
If I remember right I was not really seeing any improvements when I unparked the cores. There is some definite improvements in this regard I would expect to see.
pro-tools-pc.com
Intel I7 9900k
Win 10
  #5113
Old 01-19-2013, 01:43 PM
TOM@METRO's Avatar
This is unscientific, but unparking cores seemed to add stability with iffy situations. I have the cores unparked now and will probably leave them this way.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
  #5114
Old 01-19-2013, 02:55 PM
mykhal c's Avatar
mykhal c mykhal c is offline
i guess i was just lookin' for one thing at the time...workload allocation across all cores....the rest would show itself durin' daily usage. my rig is extremely stable and performs very well...luv'n it
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
  #5115
Old 01-20-2013, 01:03 PM
Markmanch Markmanch is offline
Out of curiosity I 'unparked' the cores of my 3820 with a 'Coder Bag' utility and cant believe the improvement. Not only have I reached a higher score on a dverb test but some issues Ive been having using my UAD1 also seem to be solved. Its too early to say for sure but it's certainly improved the stability for me.
GA-X79-UD3
i7 3820
16gb Corsair Vengeance
SSD OS drive
500gb WD black
Windows 8
Pro Tools 10
UAD1
  #5116
Old 01-21-2013, 02:00 PM
kyluigi kyluigi is offline
Hey Guys pricing out a system here on newegg. I should mention this will be my first build but I am fairly computer savvy and have some friends if I need help. I am considering building one because an i7 mac that I would like is just too expensive even used. My new studio computer will run PT10 with either a focusrite saffire pro 40 or a comparable 8 channel interface. Here is my build right now. The 500gb will be the system drive and the 1tb will be my recording drive. There is enough space for more drives should I need them in the future. Anyone see any potential problems with pro tools? With shipping these parts price out to $1272 ish. Anyone see anyways I could cut corners and still have good performance for a prosumer studio? question: will I need a T.I. pci firewire card or can I just use the onboard firewire?
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Western Digital WD Black WD1002FAEX 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Western Digital WD Black WD5003AZEX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
ASUS GT610-2GD3-CSM GeForce GT 610 2GB 64-bit DDR3 PCI Express 2.0 x16 HDCP Ready Video Card
CORSAIR Enthusiast Series TX650 V2 650W ATX12V v2.31/ EPS12V v2.92 80 PLUS BRONZE Certified Active PFC High Performance Power ...
CORSAIR Vengeance 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M2A1600C10B
ASUS Sabertooth X79 LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Intel Core i7-3820 Sandy Bridge-E 3.6GHz (3.8GHz Turbo Boost) LGA 2011 130W Quad-Core Desktop Processor BX80619i73820
Microsoft Windows 7 Professional SP1 64-bit - OEM
  #5117
Old 01-21-2013, 04:33 PM
CME CME is offline
Default i7 Builds - Specs and Results
I'm no windows guru, but don't forget the hackintosh option, if that interests you. But most if all get an SSD for your system drive (whichever OS you choose) and thank me later.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
  #5118
Old 01-21-2013, 10:36 PM
YYR123's Avatar
YYR123 YYR123 is offline
Yes sir, do what the man suggests
Daniel
  #5119
Old 01-22-2013, 04:59 AM
If I'm using a FireWire interface though guys will I need I get a TI pci card or can I use the inboard FireWire from the x79?
  #5120
Old 01-22-2013, 05:21 AM
YYR123's Avatar
Via are not recommended buuuut may work for you depending on ur interface - I was using one b/F and it was fine but ymmv - as always if its a problem u can get one later or if u don't want to mess w/it just order the card it's only like $30 dollars if I remember
Daniel
Best Core 2 Series Desktops-Results and Specs sunburst79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2416 02-19-2013 07:49 PM
new to pc builds chazc080488 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-18-2011 07:10 PM
any p45 builds fofif5792 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-09-2008 12:47 PM
OSX "builds" Richard Barrie Pro Tools TDM Systems (Mac) 2 10-18-2004 08:37 AM
