WTF!!! Are my thumbs to big?
I was wondering if anyone could tell me the optimum thumb size for pro tools 9. My thumbs seem to be getting in the way of my great music and causing a ton of latency! I don't know what the problem is. I hate AVID. My thuumbs worked really well on protools 8.04. I have googled the topic numerous times and followed all of the instructions on eHow for opposable digits but protools still makes them feel big. I almost want to switch to logic and sue AVID! Please help me get my thumbs to where they should be to make great music with protools
GoodLook Ent.
Mac Pro quad 2.66 (2010) - OSX 10.6.5 - 4g ram - Apogee Rosetta 800 - xHD - Neumanm Tlm 49 - Great River 500nv - LA2A - Protools 9HD |
Re: WTF!!! Are my thumbs to big?
Users with big thumbs are better off using SONAR.
| Logic Pro 9 | Reason 6.5 | Pro Tools 10 | MOTU UltraLite mk3 | RME ADI-2 | Summit Audio 2BA-221 x 2 | MOTU 8pre x 2 | | Mac Pro (4,1) 2.26gHz Xeon x 2 16gB OS X 10.7.4 | Macbook Pro (8,2) 2.2gHz i7 Quad 16gB OS X 10.7.4 | |
Try your fingers.
The Postman Post-Production Studio Moncton, New Brunswick, Canada IMDb (very partial) |
You need to use the ATC or "automatic thumb compensation" plugin.
Insert your thumb into your rear......plugin passage and all will be good. |
I have tried the ATC and it is a well know issue since protools 4 but completely new to protools 9. I think that the command focus thumb mode should be 64 bit.
GoodLook Ent.
Is it your right thumb or left thumb that is too big? Try using your other thumb to see if that works better. Some of us have simply stopped using our thumbs altogether in Protools 9 due to a known issue with large thumbs. Some folks have tried to use a compressor plugin to decrease the thumb size but it doesn't always work. Users of PTHD have also tried the Heat plugin with some success but it is only available in TDM format. Try looking for a wrapper for it. It might increase the buffer size however. Make sure to record to a second drive as recording to the system drive is known to cause problems with larger thumbs. It is also a good idea to delete databases and preferences if the thumbs are really large. There may be other tweaks in the General Troubleshooting thread that will help with the problem. Finally, make sure all your plugins are up to date and compatible with your thumbs. The problem may not be with Protools. You might just need to work around the thumbs. I think Logic and Cubase also are having similar problems with big thumbs.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
GoodLook Ent.
*Slaps forehead and laughs uncontrollably*
Your problem is using those big knobs on the LA2A. That's where Fat Thumb Syndrome comes from. I thought everybody knew that. I have a fix, though. I'll trade you for an Alesis 3630, straight up.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Thumbs up for 10.2 | reichman | Post - Surround - Video | 6 | 06-18-2012 06:17 AM |
Big thumbs up for 8.0.4! | tamasdragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-02-2010 01:10 AM |
Thumbs up on 6.1.2 | Garissimo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-11-2003 03:27 PM |
intel 815E motherboard / thumbs up or thumbs down? | gabadilla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-19-2001 12:09 AM |
thumbs up for Z-room! | haze | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-12-2000 09:09 PM |
