Old 09-30-2020, 08:28 PM
Starnine Starnine is offline
Default D-Command Pt 2018 Help!
Please advise
I have Avid Standard Subscription Icon D-Command,
Hd3 Accel, Pro tool 10 hd.
But I want to use Pro Tools 2018
I also have Neyrinc yearly subscrption.
At one point while testing, Pro Tools Ultimate trial, Digilink Trial, and Neyrink Trial.
Everthing worked well together. Minus HD3 Accel
Once the Trials ended.
I payed for the Neyrink upgrade.
Now nothing works together? Meaning on the Icon-D-Command
Please tell me how to make it work again?
Which am I Supposed to purchase to Make my Icon Come alive again.
Mac Pro 12 Core 3.0.6 ghz
5,1 Osx 10.13.6,
Thanks in advance!
Old 10-01-2020, 12:32 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: D-Command Pt 2018 Help!
You don’t need anything to run D Command the driver software is included with pro tools.
Whats happening? Does it just not go online? Have you gone to setup peripherals Ethernet and scanned for the D Command? Does it show in the list of Ethernet controllers? Maybe you just needed to re assign it as an Ethernet controller.
Failing that run the pro tools installer to reinstall the driver software and scan again for Ethernet controllers
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-20-2020, 12:53 AM
Hello Sir.
Sorry for the late reply. I have been out of town for a while.
But the answer is no. Pro tools 2018.12 doesn't even see the Icon D-Command on the ethernet driver. I am at a loss. I cant figure it out.
When I open the Neyrinck app. it does see the D-Command but does not activate it?
Could it be because I purchased, the Pro tool Subscription in 2020, instead of 2018. Meaning maybe I don't have the proper license. I also don't have a physical Ilok, only the Cloud Account?
Thanks
Best Regards!
Old 10-20-2020, 05:24 AM
Southsidemusic's Avatar
Is it an Ultimate subscription of PT?
I believe you need an HD license aka Ultimate as normal PT native aka Vanilla wont work with the controller or your PT HD setup.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 10-20-2020, 08:15 AM
Christopher likely has your answer with you needing an Ultimate license. What exactly shows up in ILM as the license description for the cloud license assigned to the computer you are using? If you think it is Ultimate actually check in ILM what it says. Disconnect any iLoks that might contain other licenses.
Also exactly what Neyrinck software are you talking about? V-Mon?
Old 10-20-2020, 09:28 AM
He is probably talking about V-Control Pro which allows Pro Controls & Control 24s to work with modern Pro Tools. Unfortunately I don't believe V-Control Pro works with Icon series.
Scott Gatteρo
Old 10-20-2020, 09:50 AM
Or hopefully V-Mon which does.. but that's why I'm asking.
Old 10-20-2020, 01:56 PM
DetroitT's Avatar
DetroitT DetroitT is offline
Possibly,
Find a HD now Ultimate reinstatement and upgrade your HD10.
Trade up your HD3 to HD Native will also get new lic.
All depending on Avid account items.
Old 10-21-2020, 09:12 AM
I believe V-Mon only handles monitoring duties as an X-Mon replacement for Icons. I don't think it does anything to get the control surface portion to work with non-HD/Ultimate software. I could be mistaken though.
Scott Gatteρo
Old 10-21-2020, 12:00 PM
Yeah he NEEDS a HD license to use Icon and Avid cards so no shortcut there unfortunately. He said hej t worked on the trial Ultimate and thats obvious but now with just vanilla PT it doesn’t work so that is the solution - Get a Ultimate license or keep using your PT10HD license and skip 2018 and up.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Command 8 - Meters Not Showing in 2018.7 Siegfried Meier Pro Tools 2018 7 03-16-2019 10:12 AM
D-Control and Command with 2018.12 PTPerson ICON & C|24 9 02-28-2019 03:36 AM
Command 8 working with 2018? Myles83avid Pro Tools 2018 2 11-12-2018 12:55 AM
August 2018 - a day is coming D-Command ES mgoorevich ICON & C|24 9 08-23-2018 04:11 PM
Track preset key command PT 2018 tomdiek Tips & Tricks 1 03-03-2018 11:52 AM
