Old 03-15-2013, 01:22 AM
application4 application4 is offline
Default Master bus metering -3dB
(HD 10 TDM 10.3.2 - Windows 7)
I was checking a new PPM meter and calibrating the 192's outputs.
Mono audio channel, 1khz tone, -18dB - PPM meter= 4 on the BBC scale.
In 'peak' view on the PT channel the reading is also -18dB.
That's all fine.
When I put a stereo (or mono) master fader in the chain, the 'peak' view on the master channel (and the metering / metering plugins etc) drops the signal 3dB.
The audio channel display remains the same.
The worrying part though, is the analogue audio levels going to the PPM meter remain the same as before. So the master fader's meter levels are wrong.
There is no actual drop in output level.
Has anyone else had or noticed this problem?
Old 03-16-2013, 04:33 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Master bus metering -3dB
Pan-Law although this shouldn't be with a mono-1-output fader with a mono master fader ...Assign 1 out from your tone source (No Panner)
Also if you have a RMS volt meter you may wish to double check since your in the mode.
Problom with metering master channel through my 003r via c-24 EitanB ICON & C|24 0 07-31-2013 06:16 AM
Pro Tools 8 Master Metering & Maxim JGR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 10-16-2009 01:27 PM
Pre-Fader Metering vs Post-Fader Metering teacherman Pro Tools TDM Systems (Mac) 3 01-29-2008 07:33 PM
Question about windows in PT, and Master metering stoogee Pro Tools TDM Systems (Win) 3 10-20-2003 03:06 PM
Master Metering cachemira Tips & Tricks 6 07-02-2003 12:24 AM
