Old 12-22-2010, 06:15 AM
Matt Darcy Matt Darcy is offline
Default Pro Tools LE 8 + Snow Leopard + Mac Book Pro 17'' + SSD Upgrade ?
I fully understand this is not pro-tools specific, but this Mac Book Pro is used only for Pro-Tools, so I'm really only interested in the response in terms of the Pro Tools application.
I have a Mac Book Pro 17'' (not the current version, the one behind current) that I use with Snow Leopard and Pro Tools LE 8 and a Rack 003.
I'm considering upgrading the internal disk in the Mac Book pro (not used for recording, that's all external firewire) to an SSD to improve the application and OS performance.
Will doing this cause any issues for Pro Tools ? is there a reason I shouldn't do this in relationship to Pro Tools ?
Are there any specific models versions that I should/should not use to keep stability with Pro Tools.
I appreiciate this is more down to the OS, but Pro Tools is this machines real use so I want that to be the priority.
Old 12-22-2010, 10:37 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: Pro Tools LE 8 + Snow Leopard + Mac Book Pro 17'' + SSD Upgrade ?
The only improvement you'll see is in boot time and app loading. You won't see any improvement in the actual application with SSD.
Apps like Photoshop that need to do disk swapping if there is not enough RAM would see faster access times. I don't think Pro Tools uses disk swapping to the OS drive.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Upgrade to Snow Leopard? SpongeBob Pro Tools TDM Systems (Mac) 7 11-25-2011 08:00 AM
Upgrade from Leopard to Snow Leopard... I need some guidance, please Loudyman Pro Tools TDM Systems (Mac) 6 06-21-2011 08:56 AM
Pro Tools 7.0 LE upgrade to Snow Leopard Pais_man Pro Tools 9 10 02-22-2011 10:17 AM
Pro Tools 7.0 LE upgrade to Snow Leopard Pais_man Pro Tools M-Powered (Mac) 1 02-11-2011 11:32 AM
PT 7.4.2 upgrade with Snow Leopard radair0502 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-19-2009 09:34 PM
