Import session data in one Playlist
Hi, On pro tools 10 there is a way to import different tracks in the same playlist directly ?
Or I have to import the single tracks on new track and after make the playlist ? |
Re: Import session data in one Playlist
You can't import multiple tracks onto the same playlist. How would that work?
Could you explain in more detail what you're after?
Hi Stig , I was trying to import some referents mix in the same playlist of one track. So i can use that , importing that track in a new mix section , and will have my referents mixes in one track playlist.
But i didn't find a way to do that shortly. I am doing it manually making the playlist adding one by one file at time. |
I see. You can import the files in one go to the session, put them in the clip list, then use timeline drop order left to right. If you want them back to back, that is.
Yeah , if i have understand well in that case i have all the mix ordered in sequence one after other in the same playlist .
Instead i want that one mix is reference by itself in a playlist with its own name. |
Import Session Data with out Audio import | disinfor | Pro Tools M-Powered (Mac) | 7 | 11-14-2010 11:44 AM |
import session data without audio data | rgalpin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-06-2010 01:49 PM |
End of Stream Reached - session broken - import session data does not work... | Sean Russell | Pro Tools TDM Systems (Mac) | 0 | 01-15-2010 04:56 PM |
Playlist problems when importing session data. | dougens | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-29-2009 11:09 PM |
Import track color in import session data | deardaddy | Pro Tools TDM Systems (Mac) | 5 | 06-11-2007 06:35 PM |
