Old 02-13-2011, 05:20 AM
SixChurchStreet SixChurchStreet is offline
Default White noise burst every 12 seconds.
Everything was fine an dandy on my MacBook Pro. I got a new iMac quad yesterday. Did migration assistant. When I opened a recent session, I got a white noise burst every 12 seconds.
So I updated to OSX 10.6.6, to PT 9.0.1 and also the latest m-audio ProFire driver.
Still got the noise bursts. No change.
Then I trashed my prefs.
Same thing. No change.
Is this a common thing or a new one?
Mac Pro 5,1 2.4GHz 8-Core 16GB RAM High Sierra | Focusrite Scarlett 6i6 Mk2 | Pro Tools 2020 | Studio One 4
Old 02-13-2011, 05:31 AM
mrjohn mrjohn is offline
Default Re: White noise burst every 12 seconds.
I have seen issues with using migration assistant before. If you create a new admin user and open the session from there does it help?
John
Mac Pro 2 x 2.8GHz Quad
OSX 10.10.5, PTHD 12.4.0
Old 02-13-2011, 05:32 AM
mblanton66 mblanton66 is offline
Do you have any IK-Multimedia serial number-based plugins? Are they authorized?
Old 02-13-2011, 05:33 AM
John
I can give that a shot. If that does work, what does that tell me?
Would just uninstalling and re-installing PT9 be helpful as well? Because I was thinking that was my next step.
Old 02-13-2011, 05:36 AM
I do have a few IK plugins. They were authorized and working fine on my MacBook Pro.
Old 02-13-2011, 05:44 AM
The issue we saw with migration assistant is that it can pull some settings over from a previous installation that don't play well with the new one. These may not necessarily be protools related which is why trashing protools prefs doesn't help.
These days if doing a new OS install I just start from scratch with a fresh drive and manually copy anything required from the old one.
John
Old 02-13-2011, 05:45 AM
These days if doing a new install I just start from scratch and manually copy anything required from the old disk.
John
That would be the ideal thing, but I had to do it quick and dirty. Sold the MBP so I gotta get it shipped out. I do have a clone of the MBP drive though, so if I need to do everything more manually later, I will.
Maybe i'll try to reinstall PT9. What's the best way to properly and thoroughly uninstall PT9 from my Mac?
Old 02-13-2011, 05:52 AM
Well there's an uninstaller in the installer package (or on the DVD if that's what you used). Other than that I'm not sure to be honest.
Old 02-13-2011, 05:56 AM
Ok. I'll wait till my full install is finished downloading (before this i had upgraded from M-Powered). Then I'll see if I can uninstall first.
P.I.T.A. haha. I dreaded leaving my MBP because it was rock solid, but I needed more power than the Core2Duo could give me. Hopefully I can get this ironed out eventually and be back to a rock solid system.
Old 02-13-2011, 06:13 AM
danander11 danander11 is offline
It sounds to me like one of your plugs is in demo mode. You may want to check them all.
Here I am,
after time not long...
and thankful for the break,
What I found when I got there,
was that I couldn't stay away!
Hobo Shave!
LOUD white noise BURST after bouncing. 10.2 DJ Hellfire Pro Tools 10 55 02-23-2014 08:24 PM
Burst of noise (not necessarily white noise) at the end of clips Swarf macOS 9 09-20-2012 08:55 AM
WHITE noise burst new thred DIGI Fullsound Recording Pro Tools TDM Systems (Win) 17 02-03-2010 02:58 PM
White noise burst on a track. Spyrojoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-14-2006 09:45 AM
Violent Burst and white noise in MBOX krikoro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-11-2005 02:57 AM
