full install protools 8.0.4 for windows seven 64??
i have but i laptop hp with i5 intel , i like to install on it.
exist a full install or protools 8.0.4? or i need to install 8.0.3 and afert update? where is the best way have have a good install in my laptop?
HP HP Pavilion dv6 Notebook PC Intel(R) Core(TM) i5 CPU M 430 @ 2.27GHz 4GB DDR3 SO-DIMM Memoria Totale : 4GB DDR3 SO-DIMM Velocità Bus di Memoria : 2x 532MHz (1GHz) Video : NVIDIA GeForce G105M (16 SM4.1 1.23GHz, 512MB DDR3 128-bit, PCIe 2.00 x16) Seagate ST9320423AS (320GB, SATA300, 2.5", 7200rpm, 16MB Cache) Sistema Windows : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Conformità della piattaforma : x64 maudio 410, maudio solo windows vista,quad core intel |
Re: full install protools 8.0.4 for windows seven 64??
U must hav a version of '8' before u can install 804 on it; when installing 8, just install without plugging up the interface; it of course will ask u to do so but don't; then after it installs 8, immediately (althought u don't hav to) install 804 & that is when u will plug the interface "when instructed to do so"...
Jus for the record, these instructions are on the how to install on 804 but u get a pass this time
U got it Albee'sure although I kno the answer; but wasn't asked
I don't know on these, but if you look at the update info page, there are several other updates listed(like for the iZotope plugins). I haven't checked those plugins yet as I rarely use them, but I will try them today if I get that far. I am still chasing a few odd things that are ticking me off, like inconsistent Bounce to Disk, and LLM issues(2 of 8 ADAT inputs go silent with LLM).
I wish the instructions y'all described for the Win7 64 bit PT8 worked for me. Here is my 'problem'
#1 Win7 64 totally clean install - no software on the system at all #2 PT 8 DVD install (Profire 610 disconnected) #3 I am asked to disconnect my Avid MIDI IO or Controller 8 (neither of which I have so it's not too hard to comply - I am NOT prompted to connect any audio device #4 Run the 8.04 update #5 I am asked to connect my Avid MIDI IO device or Controller 8 (Again neither of which I have but instead I connect my Profire 610. #6 It has been almost two hours of install and uninstall. Never once does the PT installer ask me for an audio interface, and never once in the very long install does it indicate that I don't have one connected. It's not until I try to run PT that I have any idea the install failed. Why is this so hard? When I get this done, I will install Sonar 8.5.3, Samplitude, Adobe Master Collection CS4, Sound Forge, Sony Vegas in the amount of time it takes me to figure this out. Thank goodness Avid doesn't try to support more that a handful of audio devices. -D |
Protools 10 Full Install | Ian Bodzasi | macOS | 7 | 10-26-2013 10:42 AM |
ProTools 9.0.6 Full install? (Mac OS X 10.8.2) | E.Rosenberg | Pro Tools 9 | 1 | 10-23-2013 10:56 AM |
Protools 10 With Windows 8 (Full Version) | auratone | Pro Tools 10 | 11 | 12-09-2012 05:15 PM |
ProTools 9.0.2 Updater and Full Install for MAC are *OFFICIALLY BROKEN* | spylus | macOS | 10 | 04-30-2011 03:29 AM |
protools 9 full install no driver found for my 002? | broken81 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-14-2010 09:06 AM |
