  #21
Old 02-01-2019, 10:25 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Re: CLA MixDown - 2 bus comp flavors?
Originally Posted by amagras View Post
GRP is one of my favourite Signature plugs, this was the first time I used it and it hasn't leave my sessions ever since
https://youtu.be/EFQygcKl5Lc
I need to pay more attention to this one. I've used some of the Signature plugs such as drums and vocals, but not so much GRP.
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
  #22
Old 02-01-2019, 04:38 PM
senghor senghor is offline
Back to CLA MxiDown plugin. I think it's great.
You can do about the same with 3-4 plugins (SSL Bus Comp, Pultec or SSL eq and ie. Waves' Saphire saturation/distortion plugin).
But with only 1 plugin it's great deal. The eq bass is about 120hz up and high its 8Hz. I have tested this myself with meters (ie. Waves' EQ-Clone), the SSL bus comp is attack bout 20-30 ms and fast recovery, ratio 4:1. GR 3db max.
I like it!
Win11 Pro
Intel i7-12700K @3,6GHz, RAM 32GB
UAD Apollo and pre-amps, Pro Tools 2023
lots of plugins
  #23
Old 02-01-2019, 05:12 PM
jaybot jaybot is offline
Yeah I find a good parallel compression is better then standard comp plugs or as long as the actual multiband compressor is good quality (in other words it controls and pumps well when pushed not flattens)so much better then just flat out compression in my ears anyway I much prefer to use multiband compression over the bass and drums and the Mastering Phase aswell over anything else
  #24
Old 02-03-2019, 11:43 AM
Carl Lie Carl Lie is offline
Nice little video you put together. Would have been nice to have you bypass longer but thanks for sharing.
C
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc.
  #25
Old 02-03-2019, 12:26 PM
amagras amagras is offline
C
Thanks a lot Carl, I'll try to remember that next time, it all depends on the amount of coffee I've had before the original screen capture.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
  #26
Old 02-03-2019, 02:40 PM
bashville bashville is offline
Originally Posted by senghor View Post
Hi.
The Waves' CLA MixDown that has two compressor "flavors". As CLA describes the plugin - he says: "If you know CLA, you know what those two flavors are."
I think the 1st flavor is a SSL bus comp.
Do you know what is the second flavor? Want are usually the 2nd flavor setting?
CLA MixDown Plugin | Waves
Thanks for your answer!
Funny I went through 3 pages of replies here, and no-one went to the manual for the plug-in. It doesn't use the word "flavor", but for that 1-2 Glue switch it says:
"There are two compressor types:
• A modern, punchy compressor.
• A compressor with a longer time constant. It is good for holding the mix together."
So yes it's probably some emulation algo as well, but it seems the main point is the attack-release times.
HD Studio, PT2022.6, UA Apollo x6, 2018 MacBook Pro, 32 Gig, Big Sur
  #27
Old 02-03-2019, 02:45 PM
They are straight emulations...of two of the compressors he uses on the master bus. Waves don't say which compressors are but CLA does in interviews and other places so everybody knows.
amagrasmusic.com
  #28
Old 02-03-2019, 04:06 PM
Southsidemusic's Avatar
Great Videos as usual Andrei
We really appreciate your videos and tutorials so keep ’em coming and Thank you for taking the time to post them all free of charge!
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
  #29
Old 02-03-2019, 04:18 PM
I'm starting to explore a more pop sound now in my songs (jazz don't pay bills!), this is a whole new world for me so I might ask you for some guidance in the future!
amagrasmusic.com
  #30
Old 02-03-2019, 04:21 PM
I think the reason Maserati GRP was originally mentioned is because one of its modes is a vwry similar Master Bus chain as well.
amagrasmusic.com
HTML code is On
BUG mixdown print track records too early with delay comp Jaim Pro Tools 10 6 02-28-2012 10:16 AM
Mixdown - mixdown pitch shift problem kakeneeditoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-03-2007 03:38 PM
PSP Master comp, nearest plugin comp to Manley Vari MU? crizdee Pro Tools TDM Systems (Mac) 1 05-22-2007 05:21 PM
Digi001 in 5 yummy flavors? zavijah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2007 01:32 PM
pros and cons of comp-eq or eq-comp dw Tips & Tricks 4 01-28-2001 03:10 PM
