Old 11-16-2019, 12:37 PM
L-Dogg L-Dogg is offline
Default Eleven Rack with Voodoo Labs Ground Control Pro
Hi all.....quick question-with a long explanation.
Setting up 11R with the Voodoo Labs GCP for the first time.....to use live for the first time....power amp/speakers etc. First rehearsal with it is later today. GCP is Version 1.3.1.
I have it set to 4 patches and 8 Instant as far as the switches. I have my 4 amp patches on the bottom row in Bank 01 etc and I am using Instant switches 1-8 for turning on and off the various effects.
I started setting it as such......
1=Overdrive
2=Roto Speaker
3=Delay
4=Compressor
So far, this has worked flawlessly.
However.....when I go to switch #5 to set what I want there.....the BS begins.
I want to place the Orange Phaser on switch 5.
I get into Edit Mode > Instant > cursor to 05 > Data up to #50 if the device is in MOD or #63 if in FX1 or #86 if in FX2 (as per the 11R manual)
Then I hit Edit...Exit Yes/No? and hit Yes.
Now.......nothing happens to the phaser when I activate switch 5.....AND.......now switch 1 has no effect on the overdrive. 2-4 still work just fine.....ONLY switch 1 is affected. I have to re-program switch 1 to #25 to get the OD working as before. Then 1-4 work okay as before. I tried using a device on switch 6 as well.....same thing....kills the functionality of my overdrive switch 1.
To me it seems as soon as I add a device to switch 5 through 8......it kills the OD on 1.
Since I was able to program 1-4 okay initially, I suspect I am missing something simple or doing something stupid when it comes to 5-8.
Does anyone have a solution for me?
BTW.......I bought this GCP used from a private party-and I have no experience with them. I have no idea what he did when he set his up or if he sold it because he was also having issues. Naturally he told me it worked perfectly and I got a good vibe off him. He is a pro guitarist and has albums etc and I'm sure he would not try dupe me. No serious....he seemed cool.
Mac Studio M2 Max
12-core CPU, 38-core GPU, 16-core Neural Engine
64 GB memory
2TB Solid State Drive
Thunderbolt 4
Sonoma 14.1.2
Pro Tools 2023.9
Universal Audio Apollo 8P (TB3 Option Card installed)
Old 11-19-2019, 11:03 AM
PRSWILL PRSWILL is offline
Default Re: Eleven Rack with Voodoo Labs Ground Control Pro
I have the same set-up. the GCP is touchy and I am not sure I can answer your questions accuratly, I would recommend downloading the manual. There are a couple of modes you can put the GCP in and this may be your issue. Make sure you're mapping the correct MIDI channel to the correct Midi input on the 11R and that the 11R is not locked for programming. I have ben using mine live for about a year and it works very well. I tend to set up my presets in their entirety and just step through them for different tones. I do turn off certain elements in the chain with the individual switches from time to time as well.
The frustrating part of the GCP is it doesnt' receive midi programming from the 11R well- it's always "in-charge" of the set-up.
Good luck with this. sorry to not be much help- but I've been there are it's doable with some poking around.
Old 11-20-2019, 10:31 AM
stormstudios stormstudios is offline
You might want to re-initialize the unit because it sounds like something wonky from the previous user.
Here's the manual.
http://www.voodoolab.com/manuals/gro...pro_manual.pdf
Page 5 has the init steps.
Alternatively, when you edit the Instant Access button #5, what does the channel / note value say? (eg. 5.CH01 CTL050?)
Old 04-16-2020, 09:38 AM
mrmatic mrmatic is offline
I am having a similar issue.
I have my 4 banks to scroll thru rigs and my 8 CC buttons that I want to set up to the 8 effects on my eleven rack. So im watching Seans video #1 and entered "instant access". Changed button 1 to CC 25 for distortion just like he shows. All good.
At 5:14 there is a video glitch or edit to show how to change from button 1 to button 3. For the life of me, I cant figure out how he did it. Ive pressed every single button to try and get it to go to button 3 or what he pressed to switch it. Can someone throw me a bone here Please? I can switch the midi channels and I can change the "CTL" But i cant change from button 1 to any other button.
Old 04-16-2020, 06:33 PM
He hits the Bank Down button with his foot. If that's not working for you, you're probably in the wrong mode. :shrug:
Old 04-16-2020, 06:43 PM
I agree that he hits the bank down button but he did something just before that where the edit is.
I saw another vid where someone did basically the same thing.
I'm just trying to map the 8 stomp box buttons to the 8 upper buttons on the GCP.
Can't seem to be able to change the button # to 2,3,4,5,6,7,8.
I've pressed every button, every cursor, every bank but I can't find the correct button to change the button#.
Any suggestions?
Thanks.
Rich.
Eleven Rack and Ground Control Pro prodigy_ed Eleven Rack 4 04-07-2018 08:34 AM
FS - Voodoo Labs Ground Control Rig brianiac5150 Buy & Sell 0 02-15-2016 10:03 AM
Eleven Rack & Ground Control Pro Template guitarorth Eleven Rack 2 03-10-2012 01:33 PM
Voodoo Ground Control and Eleven Rack Setup Please Help! HipHopWong Eleven Rack 7 11-11-2011 12:45 PM
11 Rack with Voodoo Lab Ground Control-Exp Pedal issuses philster65 Eleven Rack 1 11-10-2010 04:49 AM
