Playing back wrong files
I have a 9600/G3/400mhz w/256ram. If I have a session spanned across several hours, when I record something onto a track late in the session, it shows the correct waveform but plays back something completly different. HELP!!! As I work in Post Production on films this is a big problem. Any suggestions??
Re: Playing back wrong files
P.S. This problem is with Pro Tools 5.1
Now this problem has reared itself on a G4 with PT5.1 and with nothing else in the session, it records fine when playing back totally unrelated sound that has nothing to do with the session. HELP!!!! I have to switch back to PT 5.0.1 until this is solved as I can't have any down time
Hey Lance - I've had this happen in 4.3.1 when audio drive directories got scrambled and disks were getting pretty fragmented. Disk Warrior should sort it out for you - excellent utility! Re-initalizing your drives between projects will help avoid those kinds of problems.
One thought - was this session restored from a backup medium of some kind? Do you have multiple drives on your system? If "yes", there's another workaround, but don't want to burden you with it needlessly. Good luck. Warmest Regards, Brian |
I had the same problem - was working with an audio segment way down the time line and had the weirdest things playback. The overview looked fine etc.
Luckily, I was only working down the time line to get away from the the rest of the session and was able to drag the audio I was bouncing closer to the beginning of the session - it started working fine. Ran Disk Warrior and others over drives to no avail. Are you able to shorten the length of your session at all?
He used to cut the grass...he was a very nice boy... |
I had a similar problem once with 5.0.1. Rebuilding my desktop seemed to clear it up.
Playing back at wrong speed | budinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-23-2010 08:05 PM |
Session playing back at the wrong speed | ultrajoebot | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 12-01-2008 08:06 AM |
Midi Playing Back wrong rhythm | m01 | Pro Tools M-Powered (Mac) | 1 | 09-08-2008 10:09 AM |
relinking problem! wrong sounds playing back.. | evs | Post - Surround - Video | 6 | 02-21-2008 01:05 PM |
Playing back wrong files? | QuickPuppy | Pro Tools TDM Systems (Mac) | 1 | 04-18-2001 04:01 PM |
