DP 2.7 and dae5.1.1. Does it work?
Is anybody using these together succsessfully. I'm having problems with phase on my master channel in digital performer. Also the master channel only works with the mono button pushed in. Also I can't get the send to buss to work.
beige G3, 256 ram, mix plus,oms,studio 64XTC. |
Re: DP 2.7 and dae5.1.1. Does it work?
I finally figured out the problem. I was using Digi's high res mixer plug-in. When I switched back to the regular Pro Tools mixer plug-in everything works fine.
Thanks for the reply |
I run 2 systems like that, only with the MTP AV. DP 2.72 and PT 5.1.1 Mix+. I run DP in Midi only and use PT for Audio.....or Run DP only with DAE. Your choice. Both systems have OS 9.04.
Rob |
Audio Suite plugins that work in 10, do they work in 11? | David Sandwisch | Windows | 1 | 08-10-2013 08:14 PM |
PT LE DAE5.3.2 & useded 001 plug-ins???? | guitar hong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-04-2002 06:04 PM |
How does Direct Connect work?? (Does it work well??) | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-18-2001 08:13 AM |
RTAS not working after DAE5.0.1 and other updates? | artguilljr | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-21-2000 09:13 AM |
Extension Conflict: DAE5.0cs3 & Digi Output Drivers | imported_yes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-05-2000 01:22 PM |
