Old 11-24-2020, 06:56 AM
milan cutlac milan cutlac is offline
Default Eleven Rack schematics needed - the unit is frozen on boot
Hy, Does anyone have the Eleven Rack's service manual?
My unit is stuck on the boot screen.
Thank you!
MacBook 2.4 Ghz/2 Gb Ram/160 Gb Hdd
Leopard 10.5.4/ PT 7.4.2
MBox2 Mini
Old 11-24-2020, 12:19 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack schematics needed - the unit is frozen on boot
Did you try a hard reset?
https://duc.avid.com/showthread.php?t=345938
Brian
Windows 10 Pro 64 Bit
Pro Tools 2020
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Instagram
Old 11-24-2020, 12:40 PM
Not sure schematics/service manual ever escaped. If it did you would likely find it with Google. If a memory wipe/hard reset does not fix it, there are multiple boards, start by checking the board interconnects and supply voltages. With used units being so cheap it may not be worth spending a lot of time fixing a faulty one.
Old 11-24-2020, 10:51 PM
I did hard reset. I found that is a common issue for these, but no solution yet. That is why I need the schematics. It is hard to find a voltage problem without knowing the reference values.
Yes I could get another unit but I do not like throwing (cool) things when there is potential in it :)
MBox2 Mini
Old 11-24-2020, 11:20 PM
Voltages will be obvious with a little poking around.
Old 11-25-2020, 02:35 AM
Please eleaborate.
MBox2 Mini
Old 11-25-2020, 03:13 AM
Open it up and look. Are fault LEDs blinking? cables loose? reseat them anyhow, parts show they let the magic smoke out? voltages will either be printed on boards connectors or maybe test points or workable by looking at the regulator circuit of the chips they are driving. are transformers even putting out AC off their taps before regulation, ... do microcontrollers look alive?. This is beginner level electronic troubleshooting stuff likely worth doing quickly and none of which needs the luxury of a schematic.
The Eleven Rack hardware is quite reliable, I have no idea where you got a different impression from. The main known issue was a faulty clock circuit in one model version that does not cause issues you are seeing. The only hardware issue I have ever seen was a loose interconnect to the front panel pcb after a unit was dropped on the floor I can’t even remember the symptoms.
Old 11-25-2020, 03:21 AM
"The Eleven Rack hardware is quite reliable, I have no idea where you got a different impression from. "
https://www.google.com/search?ei=vi-...4dUDCA0&uact=5
MBox2 Mini
thanks for the tips. I will take another look.
MBox2 Mini
HELP needed before I buy an Eleven Rack dhoward1970 Eleven Rack 2 08-29-2017 10:05 AM
Tech support needed - downgraded my Eleven Rack Veiko Eleven Rack 7 06-04-2015 10:01 AM
Eleven Rack fimware update 2.0 advice needed mariusguitar Eleven Rack 5 05-31-2015 02:41 PM
Eleven Rack- No sound on Startup- Help Needed MJFrench Eleven Rack 13 01-02-2012 04:27 PM
