Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 10-26-2020, 11:23 AM
Mr. Kelly Mr. Kelly is offline
Default ProTools and video streaming
Hi all...
Does anyone here have experience using ProTools with live streaming?
I’d like to start doing small live concerts broadcast online on FB.
What video interface do you use? What would you recommend?
I’ve tried to do online research, but there is so much convoluted information.
Any help getting started that you might be able to offer would be great!
Thank you!
Old 10-26-2020, 12:12 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Default Re: ProTools and video streaming
Check out OBS. I use it often.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 10-26-2020, 01:38 PM
Thank you!
i have seen OBS, but have yet to investigate it or use it.
Is it pretty easy to configure for internet usage? I’m hoping to use an HDMI output on my DSLR camera, with the PT output as sound.
Is this a relatively easy setup with OBS?
Old 10-26-2020, 03:09 PM
Ryan Young's Avatar
It's free and very powerful. Once you poke around, it's very very easy! The hardest part for me was plugging in the livestream information. You can arrange whatever windows you want on screen (including webcams) and choose whatever audio.
I have my Pro Tools audio down mixed to stereo, and output through my optical out on my HD Omni. The optical feeds my computer's optical input so I can send it out live.
File Type: jpg Screen Shot 2020-10-26 at 3.08.21 PM.jpg (67.2 KB, 0 views)
-Ryan Young
Additional Systems
Old 10-26-2020, 05:01 PM
It probably makes sense to describe the system I am using… Since a video interface will be relative to what I am running.
I have windows 10… And my outboard preamps run through my Lynx Aurora, into the dedicated Lynx USB card.
Not sure how OBS would interface with PT with that set up.
Thoughts?
Old 10-27-2020, 11:22 AM
Benoni's Avatar
Benoni Benoni is offline
Right here
https://benonistudio.com/tutorials/s...ing-tutorials/
There are many ways to route the audio. Easiest way is two interfaces or one interface with Loopback.
Other options are Voicemeeter or for really simple stuff, the FL Studio driver.
OBS is free, and I go over your options in may of the videos, mainly for recording, but you can stream with it too.
Streamlabs OBS is another free option that makes it a bit easier specifically for streaming.
I'll have another video out later today about using Loopback with the Evo 8 and OBS
www.youtube.com/benonistudio
Even if you don't have the Evo 8, the process inside OBS is exactly the same for any Loopback capable interface.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 10-27-2020, 12:00 PM
Originally Posted by Benoni View Post
Right here
Thank you Benoni…
I’m having a hard time determining whether this protocol is meant to work with something like Facebook live… Which is my ultimate goal.
I think I read somewhere recently that if I take an output from my Aurora, and run it into my computer through the microphone jack, that I may be able to do it that way and pipe it right through into OBS and into Facebook.
I don’t monitor my ProTools sessions directly through the computer, but through an outboard system, so I would think that the system might work.
Additional thoughts?
Old 10-27-2020, 01:15 PM
Benoni's Avatar
Originally Posted by Mr. Kelly View Post
Thank you Benoni…
Sure, take a stereo out from your interface and run it into a Line Input on your computer sound card. Works fine, as long as the PC sound card is not complete crap.
I've done it that way with a Dual 1/4" to single 1/8" stereo cable.
I have a video on that method here
Check out Streamlabs, you should be able to simply login with Facebook, no need to deal with streaming keys, and be live in a couple minutes (after you get the audio part down)
https://streamlabs.com/
Although, you should still learn standard OBS. It helps when figuring out other software.
Streamlabs is actually based on OBS. If you see people talking about 'SLOBS' they are referring to Streamlabs OBS.
Once you have a basic understanding of OBS, you should be able to figure out the signal flow that works best for you.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 10-27-2020, 05:10 PM
Benoni's Avatar
For anyone reading through here, here's the Evo Loopback videos I mentioned in a previous post.
Even if you don't have the Evo 8, Loopback works the same way with other interfaces, like the Presonus 1824c I usually use.
EVO 8 LOOPBACK - Record Computer Audio Into a DAW
https://youtu.be/-G52v_8RS64
EVO 8 LOOPBACK - Stream/Record Your DAW
https://youtu.be/PBFwOqb6Bew
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
Old 10-28-2020, 05:32 AM
Tim R. Tim R. is offline
Here's an inexpensive video interface for you DSLR.
https://ikancorp.com/shop/broadcasti...k-30fps-input/
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
Pro Tools training via streaming video & digital downloads SupreGlu Training 0 07-26-2013 09:02 PM
Protools 10 session streaming on PC guileman Windows 3 06-22-2013 10:20 AM
Streaming video/audio via Ustream.com with Pro Tools daviemac Pro Tools TDM Systems (Mac) 3 08-06-2010 05:22 PM
OT: Streaming Video... Camilo Orozco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-13-2006 07:16 AM
HEY HERES A STREAMING VIDEO OF MY BAND!!!! dwdrummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 03-08-2003 08:41 AM
