I've been trying to use share audio from Pro Tools sessions during a Zoom meeting, but even after selecting "Share computer audio" the PT audio doesn't play through to other meeting attendees. Upon further research, I downloaded Soundflower and an App called LadioCast and got Logic and Garageband to play fine. What I/O am I maybe missing in PT? Logic having separate I/O device options in Preferences made it work. Can't alter the Playback Engine in Pro Tools like that though. Super new with this. Any suggestions?
iMac Retina 5k, 27 in 2017 3.8 GHz, 32GB 10.13.6 Presonus AudioBox 44VSL Pro Tools 2018.12.0 |
Buy Source-Nexus.
Ben Rubin Producer//Mixer//Bassist//Composer benrubin.com twitter // instagram // facebook // imdb ------------ PT Ultimate 2018.7, Mac Pro 5,1 12-core 3.46, 24Gb RAM, Mac OSX 10.12.6fd, SSD boot drive, SSD sample drive, Neve 8816, HD Native PCIe, Apogee DA-16X, Lynx Aurora 16, Benchmark DAC-1/ADC-1 |
You don’t need to buy source Nexus. Just install the free driver for it.
Once installed, create an aggregate device in Audio Midi Setup in the OS. For this aggregate device choose your interface ( make sure it’s not an avid one) and the source-nexus device. Take note of the inputs and outputs. Launch Pro Tools and select this aggregate device as your playback engine. Label your IO accordingly in Pro Tools and map your busses. Send audio out of Pro Tools using a send to the Source Nexus outputs in the IO. In Zoom, for your input device, choose Source-Nexus. The output device can be whatever you want it to be. |
![]() Quote:
You have to set PT playback engine to system out and then in the audio prefs of the mac to the Zoom audio engine or straight in PT, can't remember. No need for other tools.
PTHDn 2020.12 (OSX10.14.6), 8x8x8, MacPro 5,1 3.33Ghz 12-Core, BM DeckLink SDI, SYNC HD, all genlocked via AJA GEN10, 48GB RAM, Xilica Neutrino, Meyersound Acheron |
if you don't need to use an interface (in particular, if you don't need to record), you can select the zoom driver for the pro tools playback engine. i used this configuration for 4 hours of classes yesterday, and it works fine. super easy to manage.
soundflower (or blackhole) plus ladiocast (or loopback) will also work, but it's likely more complex than you need. ladiocast will occasionally drop a connection, which is a minor pain. these configurations will offer more options but are not necessarily useful for you. if you need to use your interface (for example, if recording), you can create an aggregate i/o with the zoom driver plus your interface. it's a little tricky but doable. if you're using an HD system, source-nexus is the only solution i'm aware of. |
![]() Quote:
Using a second interface is usually more reliable (and freeing) than dealing with virtual cables. But if your interface has loopback built in, that's also an easy way to do it.
Brian Windows 10 Pro 64 Bit Pro Tools 2020 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
![]() Quote:
RME's TotalMix, which came with my UFX, allows me to bring my Mic in on 1 and the far end's audio in on 3/6 through my onboard soundcard. I have a Send of my audio out 5/6 in Pro Tools and that is sent to 5/6 out on the UFX, which is looped back to 5/6. In Control Panel>Sound I have Playback as my RealTek Speakers and my Record as the UFX's 5/6, which is the "microphone". Then just set those in whatever app is open in the browser. And make sure your browser has permission to use your "microphone". Other apps that I haven't tested, but should work the same because they too work through a browser are: Cleanfeed, Connectionopen and ipDTL.
Take your projects to the next level with a non-union national read at a reasonable rate Demos: brucehayward dot com Source-Connect: brucehayward |
![]() Quote:
If you're on Windows a simple way is to use the free FL Studio driver. But this works best if you don't need any DAW inputs. And there's the free Voicemeeter Potato, which I've done a full video on walking folks through it step-by-step. But my personal preference is still using another interface or loopback.
After updating Zoom, playback engine shows “Zoom Audio Device” as an option in PT. Works like a charm. But also good to know about Loopback. Thanks everybody!
I'm trying to stream audio output of Pro Tools and a live mic to Zoom for teaching purposes. When I set the Zoom Audio Device as the playback engine in PT, I get told it doesn't support a samplerate of 44.1khz.
I've done these teaching streams with other DAWs before and used a CoreAudio Multi-Output device and soundflower (or Blackhole) to route audio simultaneously to my headphones (via my interface) and the stream. I'd also use LineIn to send the live mic to Soundflower so it goes out to the stream, and use the Audient software mixer to route the mic signal back to my headphones for monitoring. I don't seem to be able to do this with PT, as using the multi output device just gives me garbled audio. Anyone running a setup like this at the moment? Would love to hear how you've reached a solution. THank you! Edit : Made a 48khz session and set PT to ZoomAudioDevice playback engine. Did a test meeting, but on the recording there's no audio from PT. Edit 2 : Loopback was still operating in the background and intercepting the audio stream. Uninstalled it and it's working fine now, but the ZoomAudioDevice stuff sounds heavily limited. I was able to use the PT Aggregate Device to send audio to both my speakers and soundflower, and set the mic input in Zoom to that, and it works well if you've got original audio and stereo sound enabled. It's all very frustrating though. Last edited by A Chapman; 04-06-2020 at 07:18 AM. |
switching screens & screen sharing | musicman691 | General Discussion | 2 | 10-12-2017 12:31 PM |
Screen sharing causing 9173 errors | dankin | Pro Tools 12 | 2 | 08-31-2015 02:25 PM |
Screen Sharing - PT having issues when Overdubbing using VNC remote | joeldadrummer | macOS | 15 | 01-12-2011 10:34 AM |
Screen sharing + Spinning Beachball ? | T-Low | Pro Tools TDM Systems (Mac) | 8 | 03-25-2010 06:02 PM |
